Hamilton, Maldonado there sides of the story
pf1
(Maldonado)
Hamilton told his team it was "done deliberately", however, Maldonado insists that wasn't the case.
"It was a difficult moment, there was no reason from my side to have contact and from the side of Lewis," he told the BBC.
"It wasn't rainy conditions and we need to understand what happened. There was no need for contact after the chequered flag."
Pressed as to whether his coming together with Hamilton was deliberate, he said: "No, no, I don't."
(Hamilton)
The Williams was just sitting there, it was very slow. I had to try and get past, which I did
"He came around me, I didn't move anywhere, and he tried to swipe across me. I don't know if it was intentional.
"The front wing was quite badly damaged, the sidepod and I think front suspension was damaged, front toe-in was a little bit out."
He added: "Once the flag was out and the red light was on there is no need to be racing. There should never be an incident but unfortunately there was."
(end result)
the stewards believed Maldonado deserved more of the blame for the incident and have penalised him just five places on Sunday's grid.
Hamilton, though, did not escape entirely as he was given a reprimand.
schumi
pf1
"Well, obviously I would have wished for a different end to today's qualifying, but it is difficult to drive on three wheels - even if I should have the experience to do so in Spa.
"Seriously, this is certainly something that should not occur, but then this is also Formula One; we are working at the highest level but still things can happen.
"At first, I wasn't sure what had happened, as I just felt myself lose the back end suddenly which is why I instantly apologised to the team. But then I saw the wheel off the car and understood the reason why I had lost control.
"Trying to find the good in the bad, I'd probably say that I still have some fresh sets of tyres left, and that there is only one direction to go tomorrow: forward."
do you like my newer shorter post whoring posts?
Having only seen the one vid on youtube, how did Maldonardo get the harsher reprimand?
Lewis was the one ducking and weaving and looked to turn right into the Williams.
I know they were coming up to eau rouge, but if a car is beside you, generally you don't tune into it.
Anyone got other vids of the incident?
Snowie, they have layed concrete at Snowy corner. You are now good to go :)
And because I am a tragic with no life i often go back and watch this over and over...I came so close to holding the lil R400 flat :)
I havent experienced the birth of children, marriage, or much sex for that matter. so sadly, this is truly two of the most fun days of my life :)
100% Hamioltons fault. Moving over on the poor Williams driver...he didnt even have both hands on the steering wheel. Hamo should start from the back row...which puts Webz 2nd :)
i dunno about that. i've looked at both and straight out of the corner hamilton swerves across a little bit then backs out of it. then after that he keeps his steering wheel in pretty much the same spot when the accident occurs. if you watch the incar footage from hamilton you can see that his car stays parrallel to the grip markings the whole time before the crash (other than the initial swerve), while maldonado swerves over to the right hand grip positions then starts to come back across. i think they are both to blame, but maldonado more than hamilton. oh and i'm not much of a hamo fan, so no bias, just going off the footage.
The in-car is the damning footage for Maldonado imo. Hamilton does have a bit of a go as Maldonado pulls out from behind him,hence the reprimand, but then from the in-car Maldonado clearly comes straight across the front of him and continues across the front until he's pretty much on the opposite side of Hamo...
both at fault at monaco. maldonado should've been watching his mirrors and known that sir ramsalot was coming up the inside and to keep well clear. hamo should've realised that he wasn't going to make it and pulled out of it earlier
pf1
Mercedes have launched an investigation into the cause of Michael Schumacher's accident.
Team principal Ross Brawn said: "I'm disappointed for Michael because the conditions would have suited him perfectly.
"We need to look at exactly what happened, but it would appear there was something amiss with the right-rear wheel attachment.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
