Funny how 0.5 sec is an irrelevance in the real world, yet an eternity in F1 terms. damn that quick little barstid
surely 2012 can only get better for him
Year for the second title?.. if somehow the RB8 manages to be a dog all season
hmmm...
Webz has a brain explosion in an interview and puts it on the front row. Only 3 tenths behing Seb in Singapore is a good effort. he has been positively shit around Singapore in past years. lets hope Vettel pulls a heart muscle and gets too hot to bother and Webber can bring it home.
First corner will be interesting :)
mr predictions for tonights race
hamilton takes out vettel at the first corner
button has a relatively ordinary first half of the race then comes home like a baws
webber half a lap down by the time he manages to get to the first corner, then he too comes home like a baws until he tries to shortcut the track by launching himself over the wall, using a slower car as a kicker ramp (valencia 2010 style), and then in the interview asking what happened he just says "yeah, i fucked up"
... What is his longest run of points finishes and when was it?
So getting back Heir Hackness. Maybe I am over stating the significance, but his longest run of points finishes without binning cars and crashing etc was the first 9 races of 2007! His best run of consistant, solid race results was his first ever, 9 F1 races.
To me that says his head was in the right place when he first came into F1. He was focused and most importantly disciplined and as a rookie, no doubt concerned about his arrival and impact in the sport...showed amazing maturity to be so fast and consistant.
Then, he seems to have figured he has proven his point, his discipline disappears and the real, show boat Lewis who is a tad petulant and hot headed turns up to GP weekends, who way too often throws away points for Mclaren...yet still wants to be thought of as one of the best in F1.
Sure, he may be one of the quickest most natural drivers in F1, but results speak volumes and he has thrown away so many points...he needs to get his sh1t together if he doesnt want to go down as a lucky 1 time WDC who in his time was left for dead by the likes of Vettel, Alonso and some of the young punters who are coming up through the ranks
that's pretty much what i tryed to say. :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
