roy, you were right...
mark webber.
"I'm hearing about a misquote about my plans to fight for the title next year, always possible to miss/add a few words for a good story."
drs zone for suzuka
Edited by tweety bird
Bahaha agreed.
Though looking at the times the end of Bathurst will coincide with the start of the Japanese GP.
Bathurst will probably run overtime though, good old safety cars domokun.gif
but before the f1 race you have to listen to Greg Rust and Daryl Beattie for a hour.
bathurst or japanese GP?
V8's>> :iluvff: <<suzuka
Suzuka is the biz-ness. Gotta bring your A-game to cut a good time there.
As I watch the Senna lap I continually have flashbacks to the 11ty+ million laps of it I've done on GT5. lol
Just got F1 2011, opening sequence is pretty good...Has actual moments from this season, like Hamilton trying to pass Button in Canada and f**king it up lol
Noticeable graphics improvement from 2010?
Kers and Drs?
Sure- tried to carry too much speed through degna 1, then crashed at degna 2 by not being able to brake hard enough for the turn-in thanks to having wheels on the edge of the track
That'd make sense if he hadn't jumped on the gas again out of Degner 1. He had plenty of time to slow down, just chose not to.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
