I think fans really gloss over how serious the lack of ability to take instruction the Redbull guys seem to have. It seems like a bitter personal grudge match between the two.
They get away with it because their package is dominating. Pressure from Redbull management is far less intrusive than for teams like Mclaren Ferrari etc. If Seb was 4th in the WDC and DNF'd his last race, then went for fastest lap in the next race while leading, his antics would not be looked upon so favourably.
The problem is, i think he'd go for it anyway. More power to him if it means that much to him, but it will bite him soon and hopefully the consequences arent championship changing for him
Yeh, seems rather petulant. I mean Vettel does it and the team all smile and say "naughty boy" whilst grinning. They tell Webber to back off at Silverstone and he still gives it a nudge for a lap or two.
The drivers are still out for themselves and not the team. I hate RBR now so fark them. As soon as Webber steps aside I will not give two sh1ts about what happens to them.
C'mon Roy you will. You will be the same as me. Sitting on the lounge watching the race muttering crash you fkn fkr over and over again.
heard some talk from James Allen in regards to Kimi signing with Renault Lotus for 2012, with a swap to see Senna in the Williams.
EDIT:
Due to time from reading emails on the bus to work this morning and actually checking new sites:
Renault confirms Kimi Raikkonen will return to Formula 1 in 2012
http://www.autosport.com/news/report.php/id/96573
Edited by Whiplash
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
