Just after abit of advice.
My car has been sitting around for nearly 12 months, the last time it was started was 1 month ago and it was only let idle for about 10mins...
Anyway the car will not start anymore, it will wind over constantly but will not fire.
What I want to know is could the old fuel be the cause of the car not starting or would old fuel just cause it to run rough?
https://www.sau.com.au/forums/topic/344920-wont-start/
could be a number of things ie plugs maybe fouled and bad fuel pull a plug out and earth it get someone to crank it c if it sparks. if so fuel issues...
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558432
It's unlikely to be a problem of fuel quality. After all, the fuel is simply a mixture of liquid hydrocarbons that form an explosive mixture in the presence of the correct amount of air. While the fuel may go "off" with time, it does not go so "off" as to no longer form an explosive mixture in air.
You probably fouled the plugs last time you started the engine. Take them out, clean them up, try again.
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558450
When your trying to get it to fire, is it just making a ticking noise?
I'd be giving the battery a charge up (even if it still has power to turn on lights etc), when you kicked it over a month ago, it still might have had enough power and you only let it idle for 10mins therefore it would not have been enough to fill the battery up and you need a larger charge in the battery to get the straight 6 to fire.
Plugs seem unlikely and a lot more effort to go through to double check as a cause.
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558495
nah he said its turn over fine, so not battery,
I'd be checking the plug & spark, as mentioned, if thats all fine must be fuel supply?
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558525
my car sat since december last year, had started it twice in that time and fuel seemed to be fine, running 14psi with no knock so it shouldnt have stopped it starting, unless it had bad fuel, was it running bad when you parked it?
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558547
Thanks for the response guys, Im just trying to nut it out and it makes it even harder because Im in a sydney and the car is back in tas and Im just relaying the info my mate is giving me as he is the one who's having the dramas trying to start the car.
It really must be something minor and i was hoping to be able to find out on here what it could be before I have to pay someone to go and sort it out for me.
Yeah the car was running fine when it was last started.
Its a fresh rb26 engine thats only just been run in and had its first oil change.
The only thing thats been changed since the last time it was started 4 weeks ago is the battery was removed from the car.
A new battery was then put in the car yesterday and now it will not start. It will just wind and wind over but will not fire.
Can anyone tell me what fuses may be blown so i can have that checked first? I highly doubt that the spark plugs are fouled or anything like that as nothing has changed or been touched since it was last started.
Also I doubt its a fuel issue as the pumps prime up fine when the acc is on and after winding it for a bit you can smell fuel.
Does anyone know if it would be of any help if i plug the laptop into the Vipec to see if thats bringing up any faults or anything?
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5558945
Just check any of the fuses that play a part in the ignition of the engine.
Also, if you havent already, check for loose conections with wires etc etc, Simple things like that get overlooked so often :ermm:
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5559123
I would also check immobiliser if it has one and make sure no wires have come off the terminals when the battery was changed.
Good thought, but dont all immobilsers actually stop you from being able to turn the engine over? i know mine does (it was scared me a couple of times when the immobiliser hasnt detected the sensor and just been dead :ermm:)
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5559126
Some will just cut fuel and spark, which is the best imo coz then if joy rider goes to steel it they will just think its a POS and wont start, if nothing happens at all they may start ripping shit apart to try to hot wire it.
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5559134
I stand corrected :ermm:
https://www.sau.com.au/forums/topic/344920-wont-start/#findComment-5559150
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
