Hmmm... $5200 for 3.4Ls...
Or $1500 for 5.7Ls... I know which I'd prefer... :D:P
But then its not a Skyline, and I want my Skyline to be a Skyline. That is all your aircon and alternator and dash wires etc etc etc all plug in and line up. I've had engine conversion cars before and while the 'other' motors performance was better, it was a PITA when you went to o anything like turn your headlights on or believe the speedo and dash or use the aircon and even stuff like lining the gearbox and rear diff up so that you didn't chew out bearings and seals - its never that simple. I'm way over ever doing that again.
However using the 3.4 you don't have any of those issues because its the same motor by the parent company but uprated. Everything fits, the engine mounts, the clutch, gearbox, wiring, you name it, it fits. And the cost may be a bit more [but not that much more than a normal RB25/30 with forgies etc] to start with, but you will get that back and then some in reliability and not having to mod or 'bend' other parts to suit.
Of cause others will disagree, but it works for me.
  • Replies 174
Posted Images
couldn't agree with you anymore - gtr (or gtst) needs to run an rb :)
Ive been very interested in this once i saw it, but when i went on youtube, there is only a movie of the motor starting and idling.
does anyone have a link to an actual running motor?
no, not in the slightest im afraid.. :(
kinda sucks huh that this thread is a little old now. I would think that SPOOL would at least sponsor some peoples cars to test the new kit so they have an idea of the pros and cons: as a nice street motor with -5's would be my favourite even with a 7500rpm rev limiter.
Testing on tracks at constant high RPM and even some dyno queens with 1000+ hp
Many members with an rb26 are rebuilding ATM, maybe some of them can contact spool and ask to be a test/promo vehicle.
^^^I've already got insurance!!!
lol was that a troll remark about the insurance company "shannons" i was referencing to the film festival episode of southpark.
but seriously it is kinda gay nothing has been done yet, like sponsored cars or any other builds. atleast they should show a video of the car actually driving!
so buy a prototype to see if it blows up and post results here?
All for base price of 25k lol
what do u get for 25k? that is rich!
i built my rb30 complete long motor with head work, cams, rips sump, turbos etc for under 25k :)
Oh its actually pretty good. worlds first rb34 running 600hp in a clean series 2 4 door 33 with all the goodies.
http://www.spoolimports.com/used-performance-parts/car-for-sale-spool-rb34-610rwhp-r33-skyline
Edited by 045HOW
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
Currently have our rb34 underway atm. Hopefully have it back next week ready for assembly. Wont be until early next year when its ready to run though.
I must say the quality of the kit is astounding. The crankshaft looks mint.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
