Paul managed a 53.48 on the sprint with a small amount of casual water in the dipper section.
I managed a 53.9 today, dry track and not that pretty a lap. caught myself out braking too deep into turn 5 whilst watched Aaron Hodges in his crazy Escort park it in the dirt at the hairpin of turn 6 (1:45-1:50)
Edited by handbrake
thanks Drew, saw you got a 55.04 out there today. did you manage to crack into the 54.xx's? Bill was hitting some PB's also
its been said before, but damn these cars are quick!
Edited by handbrake
didnt do better than 55. group a and b joined as one and I couldnt get a full lap in without going off line. Then out of fuel.
Yes, damn quick cars! cant wait to get back out there next year
Thanks for the Vids made my lunch that much more enjoyable :thumbsup:
That overtaking manoeuvre looked like he was overtaking the Porsche at a standstill!!!
I met Paul a few years ago friendly guy, did he give any feedback in regards to how driving your car compares to others he has driven?
Thanks for the Vids made my lunch that much more enjoyable :blink:
very friendly and generous with his time.
he was very surprised by the performance of the car. he thought a while back that we might adversely effect the performance of teh car with our mods but he was very impressed. so much so that when he got back in he wanted to devote a few sessions on the other tracks with no traaffic to see what he could get.
his only comment was to get new tyres on the thing! he reckons that with new tyres and suspension tuning on a dry track we would break into the 52's on the sprint with no more mods.
will get along to some stokell days at lakeside and morgan park next year to get some more 'data laps' with him driving. one of the big things I noticed with him driving is that the car is begging to be hustled through the slow corners adn can carry enormous speed through the high speed sweepers. with so much grip you could be extremely brutal with short sharp accelarations and braking in the slower ares of the track without really upsetting the car too much - no coasting! the short jabs on the breaks in the tight corners really does help the car turn in better
After having casually looked at yours and other guy's lap times in this section, it's interesting to see how they compare to a pro. Well done for being so close too!
I can imagine it would've been very helpful to speak to him and see him put the car through its paces
Paul had very little time to get familiar with the car and the track conditions were not the best.
I reckon with a little more time in the car and better track conditions he would be close to 52's without new tyres!
Martin, the brakes have been working really well thanks.
The transmission also is keeping under 125, usually just on 120. when I forget to flick the switch (we have it hooked up to a switch, not triggered) temps can run up to 130-135+.
Paul likes the power at where it is, and reckons not to push for more. Having said that he also said that when it was stock!
Yes, I have a little bit of nerd work on the workstation at home to do with the circuit tools software to find the tenths (or seconds!)
gotta have something to do whilst the car is out of action for the next few months. beats watching another run of masterchef or whatever with the missus.
I notice more throttle between corners 3 and 4.
Also, count through the gears as Paul is on the front straight. It looks like he goes down to 2nd gear on the last corner!??
btw Drew, you need a Vbox. should look into it.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
