Well looks like both the oil seals have gone in my hks gt-ss, so i will need a rebuild kit.
Is it possible to do the job myself? (is it as simple as swapping out the worn/damage seals?)
Also does anyone have the part number for the oil seals? and do i need anything else?
(the shaft and wheels are fine on both turbos and spin with min shaft play)
https://www.sau.com.au/forums/topic/345426-rebuild-kit-for-hksgarrett-gt-ss/
Seals are just stainless steel C clips. When a BB unit blows smoke it means its 90% had a rub on the housings and needs a new core.
i don't know if they were blowing smoke.
the turbo have aheap of oil in the rear housing, and the front wheels looks like its cover in oil dirt. also there seems to be oil in the inlet were it connects the the manifold
how can i check the core? the turbos are a year old. no shaft play (very min, and spin nicely)
edit: bought the turbo 2nd hand and seller say wasn't blowing smoke :S
Edited by Kaido_RR
Check the oil drain to make sure its not blocked, and nothing is leaking oil onto the housing it self.
If it isn't then I would pull it off and have it check out. BB turbos can only be cheaply rebuild before wheel contacts.
thanks hypergear i will check it out :P
i took them to a garrett dealer here and they said they could be repair, part was $200, labour $300 and rebalance is $75 so works out to be $600 a turbo. If it is a simple swap of a part i rather do it myself than pay the $300labour per turbo.
so i am assuming that they didn't notice any wheel contact.
the oil isn't coming from the pcv/breathers is it? that wouldn't explain the oil in the rear housings though i guess.
Edited by O2 Autosports
I would just pay the money. if it's not done right and they fail the next repair bill will be $1000 per turbo or more (ie bin them and buy a new set). bummer. this is when cheap second hand turbos don't work out cheap.
normally i would agree with you beer baron, but the place i took it too the main sales guy was an asshole to me keep telling me my turbos weremt HKS because they were no marking on the housing and that all hks turbo have marking on the housing, at which point i try to explain to him that the new GT-SS and GT-RS do not have HKS marking but he continue to try and tell me otherwise. and talk down to me
This is the 1st time buying turbos from yahoo that i have had an issue :S oh well even if i have to get them rebuild still cost me cheaper than a set of brand new garrett :)
Edited by Kaido_RR
ok well in that case don't take them to that place. send them to GCG in sydney they can do it. the turbos must have been bloody cheap on yahoo which gives you an idea as to why they are stuffed....
sold for 60,000yen LOL
Will give GCG a call cheers beer baron
So they sold for about $740, plus getting them here etc and I'll guess import monster commission, let's say $900. Plus the rebuild, which GCG are not going to be cheap, looks like buying dash 9's was the best option.
Surely someone wouldve told you that in your build thread?!
Do you think i would have bought them if i knew they were f**ked?
I have bought many turbos from yahoo and never had an issue, however this time i luck out no big deal, off to get rebuild me thinks :ermm:
Sorry to hear that Kaido
GTR turbos are not something I will ever do second hand!! So painful to change - not like FF and smaller capacity single turbo cars where you can change a turbo over in 30mins.
yeah, didn't like the look of them when i unpacked them so, through i better get them checked out before i spend a whole day putting them on lol
I have bought many turbos from yahoo and never had an issue, however this time i luck out no big deal, off to get rebuild me thinks ;)
Well of course not, so many gtr owners won't risk it-I guess you're one of them now :)
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
