Was it actually too low, or were they just saying that? Its always good to know exactly, then you can say "get out the ruler, I *know* its legal".. then they defect you for something else
At least no fine.
better watch it, they'll fine you for comments like that :wave:
Nah, this copper was on the ball.
He was sitting on the side of the road on Springvale road on top of the Eastern freeway just watching people drive past, decided I looked as good as any, so he pulled me over up near tunstall square, and I was carefull not to park anywhere illegal!!!
Then he pulled out the breatho (at 11 am on a Sunday) and then pulled out a wodden stick with a roller on the end which is 100mm diameter. Said all the official stuff, and rolled it right under my middle muffler and sure enough its about 10 mm too low.
He checks under my bonnet for any "after market blow off valves or things like that" of which there were none.
tells me that he will give me a canary but not fine me etc. etc. and he was acutally quite reasonable.
He was in a Blue Highway "Safety Car" and knew his stuff.
Bit of a pain in the arse being done, but he couldn't have been more up front, honest, calm and actually quite a nice guy.
Anyway, time to put the stock exhaust back on!!
BASS OUT
QUOTE: He checks under my bonnet for any "after market blow off valves or things like that" of which there were none.
huh?!?!?! aftermarket blow off valves
Ive got a blitz one hanging off...is that illegal???
how much do i get fined :D
of course its illegal if its not plumbed back (although try to explain that to the officer).. first thing another member of our forums got picked on when he got pulled over was his BOV. Both myself, and his car were inspected and erm, yeah.. all the got him on was the BOV.
They're not a good idea, and anything external cops can see/hear from a distance, or close up, they *will* ping you for it. Often the stealth approach works well.
I think the standard defect cost is $125 fine. Get 3x of them, and that BOV is costing you more than its worth.
Bad luck Bass :D
They are being a tad on the opressive side at the moment. Lucky it's the sticker and no fine (same as me) - just a waste of your time to get it fixed though.
I wonder how high the pursuit Monaro is?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
