Im after info on how to get my 260rs to drive in rwd.. I know pulling the fuse is bad for the car but i read something about unpluging a wire and pumping the brake pedal or something like that any info on the subject would be great ive tried to use search but im either to drunk or to simple to get the answer im after thanks in advance for any help..
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/
if its s2 stagea, the green plug with 1 wire hanging from it, under the drivest side kick panel, turn your car on and press brake 5 times quickly within 10 secs. then 4wd light should be flashing. all done
I wouldnt be doing this.
Do it properly and remove the FOUR bolts to the front shaft and if you dont want a warning light pull the fuse at the same time.
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5568636
the s2 should be fine with it, i have the r33 user manual and it states in there that that is a "factory diagnostics way" of putting it into RWD, releases clutch pressure to the front drive aswell.
plus i think its also been said here a by a couple of people aswell. i havent had any wear on my front transfer case either, just last weekend i pulled my box out for a leak problem so i took the time to take it alllllll apart to give a thorough check. all seems nice
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5568745
that is the PROPER WAY,& IT`S A WINNER, ON SERIES 2 ,
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5568998
It may say that by disconnecting the wire it will put it in to two wheel drive mode but i bet it doesn't say you can use it for doing burn outs or driving hard,
there is probably a warning in the manual saying that it is only to be used for diagnostic.
I know I wont be using the wire to make it a 2wd car,
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5569188
1. in the manual there is no warning, 2. so how can it become full 2wd but not be able to do burnouts?
the wire + brakes releases the pressure on the clutch plates in the transfer case, the fuse does not.
fuse will still have the clutches slip but not engage.
but each to their own, i havent had any trouble while driving and i havent had any wear and tear in the transfer case, but like everyone says, if you dont trust it, disconnect the front just in case.
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5569324
What i was trying to say is its one thing to put it in 2wd and drive for short/normal driving its another to put it in 2wd and thrash the shit out of it, didn't some one say it was for diagnostic? doing diagnostic tests is a little different to drifting.
But as you say each to there own.
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5569373
It's for turning the front wheels off completely in case there is an issue with the 4WD system.
I run mine in RWD pretty much all the time, my 4WD system still works perfectly when I want it to and in RWD it cops a lot of punishment.. plenty of burnouts, several laps of Barbagallos etc.
Believe the hype, or believe the people that have proven it works.
https://www.sau.com.au/forums/topic/345651-awd-to-rwd/#findComment-5574554
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
