  • Replies 48
Posted Images
why the hell cant we just announce dodgy traders? it really shits me. if this were a dodgy private sale, there'd be no problem naming them.
why do the rules protect dodgy traders, when its likely that sau users will buy from sau traders BECAUSE theyre sau traders! ie. assumed to be trustworthy.
PM please.
PM please.
im pretty sure its got something to do with skylines australia getting sued as it has happened to other car clubs in the past.
Damn Al how many black cats have you run over recently?
Sorry to hear about the dramas and hope it doesn't end up costing you too much....would there be any point in contacting the rim manufacturer considering the rim hasn't actually been damaged and therefore could be a manufacturing fault?
I'm waiting for the New Year to come, 2010 has not been good for me and my car ;)
Having said that she is already looking better than ever, thanks to MiColour and is performing and handling better too! Drove really nicely at Mt Bulla and DECA, took the thrashing without missing a beat :P.
The rim is a Desmond Regamaster, i think production stopped in the late 90's. I like the rim because it suites the era of the car.
Not the best pics but you get the idea
Pic 1
Pic 2
I have replied to all PM's
I am not going through this thread to see who needs a PM, so if you want to know who the trader is just drop me a PM, much easier for me to just reply to.
I am actually surprised how many other people have replied back with similar issues with this person or know of him, as being a bad trader/business
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
