thime has come fo me to look at upgrade
i have rb25detneo in the 32
ill list the current mods
gcg 3076 the one withthe skyline rear on it
axpxi 3" exhaust
generic 3" dump
sard 650 cc injectors with hks fuel rail and hks iun tank gtr pump with sard reg
tomi b spec cams
hks 1.3mm head gasket
generic made intercooler
ok heres my thought ive live with the out of controll boost isue for a wile
so what ime thinking
garrett .82mm t2 twinscroll rear
6 boost mani to suit
wastegate what size i dont know
so new dump
and maybee one of those plazaman plenums with 80 mm tb
and wack onthe greddy cooler i have had sitting around for a wile
ps it has power fc and a avcr along with pwr radiotor lower temp thermostat etc
any sugestions much appricated
Edited by neo32
  • Replies 40
your injector size is wrong, 260cc is smaller than factory, double check what you have
and what on earth is a garrett T2? where did you find this from?
how much power do u want to make
First thing's first upgrade those injectors! 260cc would max out before 300hp, which is no use to a GT30 turbo. Go for 500 or 750cc depending on how much power you want to make.
Don't get a T28 flanged turbo, go T3, skylines hate small turbos. What's the deal with your turbo at the moment? Are you saying its a highflowed stock turbo with the CHRA of a GT3076? If so, just order the front and rear housings to suit, and make your own genuine GT3076r! Get the .82A/R external gate rear housing.
As for wastegate, 44mm Tial should do the trick, Tial gear is cheap and good quality from the states - take advantage of the good aussie dollar atm!
sorry about the errors i have a gt3076 gcg special with the skyline rear housing on it .63 ar was thinking twin scroll to keep it responsive and .82 to give it some top end legson current build lookin at a safe 280
but who knows after a engin rebuild 350 + but i dont want to be messing with turbo again
made the mistake last time and not doing enough research and rushe my purchase base on price and car sitting at tuners broken
thanks again
paul stop being a hater lol
Hater?
Realist mate. I ain't going to tell you that it'll make 350rwkw+ if it simply won't.
As you said you don't wanna touch the turbo again, you'll wanna work out now if you want 350rwkw+ or not, thats the point you kinda missed.
.82 rear internally gated low mount will be ok for 300rwkws. The twin scroll's available in .84, I personally experienced no difference, might change with a twin scroll manifold.
If you want to crack a good 300kw, save yourself the cash and buy the .82IW garrett housing from GCG.
Drop the car off to a good mechanic and have them fit the housing and make you a nice dump for it. Make sure you have the big can actuator in say 18psi to suit.
Cost you under 1500 with a new tune and all I will say, 300rwkw and a massive smile on your face.
For reference if you go a 6boob twin scroll you are going to put a hole in 5 grand. (2 gates + manifold 3k alone)
GL
change the turbo housing from t2 to t3 to keep Paul happy :)
Your talking about some serious mods here, I would expect min 12k to have anything actually running and the potential for a lot more $$.
I agree with GTScott, put a 0.82 garrett housing on it with the appropriate dump pipe (GCG can sell you this) and that will get you a nice 300rwkw for very little cost.
true twin scroll manifold needs 2 wastgates you need to add labour and other un forseen costs that could arise and tune will probally be a bit more, just change the rear housing and put a gate on the manifold and get a retune the stock manifolds have been proven to flow 300KW so your just spending money you dont have to.
Plazaman plenum looks great i had one ... cant use it anymore though due to motor change....really makes changing plugs so much easier :P
GL
I got the manifold twin scroll turbo, and twin 38mm waste gates, and lines for closer to 4k from Kyle at 6 boost.
