Before the crash, the search function wasn't working properly either. Sorting by date was selective, and you'd get stuff that was 7 months old in front of new posts 4 pages back. I really hope this will be fixed, as it's the only way to keep track of posts you've made and other persons responses. It doesn't have to be tomorrow, but sometime soon if possible as I miss this most about the about the older forum.
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5608122
Hey guys,
Been trying to address the problems, there are a few outstanding, heres my list of problems (let me know if I have forgotten any)
  • Search not going back far enough
  • Cannot add feedback
I'm pretty sure that everything else is ok now... Or have I missed something?
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5609861
Hey guys,
With userbars, if say someone is a member of "Group A" as their primary, and also has "Group A" in their secondary usergroups, the userbar shows up twice :P Technically people shouldn't have this setup, but it seems a few users do.
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5609996
Yeah I just fixed the userbars up.
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5610009
Hey guys,
"Posts by users" doesn't show any results now. But maybe you're already playing around with the search function to fix things :)
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5610017
Sweet, the search is working again.
PranK, will you get a chance to look at the search results ordering issue? Have included a pic to show you. It should be showing newest posts first, but it's kind of all over the place.
I have it on the default "View all topics started and posted in". When I change it to "View all topics has started" the results seem to be accurate in showing newest first, so it's a problem with the combined setting it seems.
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5610276
one thing i have noticed is when i get a new pm in my email i click the link and takes me to the new conversation cool, but when i look @ the top of page always says i have 1 new notification and its always the one i just read
also
have Invision taken the ability to have a PM button on the forum page to PM someone you have to go to there profile
i also notice trader rating is no longer on the forum page
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5611228
You sure there are no other unread convo's in there?
also
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5611628
Hmmm, strange... Will check it out.
https://www.sau.com.au/forums/topic/346495-sau-30/page/17/#findComment-5611634
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
