Any body else having problems tonight? Every second thing I click on goes to a blank page.
Hey Phil, Check if you have a "drive" ad being displayed when this happens.. I've been getting blank pages when this ad appears.. Semms Noel is also.. Could be the root of the problem..
Also ash. Can we add the Garage system to that list? Didnt see it discussed anywhere.. But no longer have your garage under your name/profile? Unless its being scrapped or something..
Edited by .:: GimpS-R34 ::.
https://www.sau.com.au/forums/topic/346495-sau-30/page/22/#findComment-5691292
Look along the top bar
* Skylines Australia
* Forums
* Members
* Calendar
* Gallery
* Portal
* Trader Ratings
* Timeslips
* Garage
Still there :)
GHOSTRun - donations have been inactive for over 2 years now.
Yeah i know its there.. Moreso for another user to get a direct link to your garage.. Just a useful tool for other users..
https://www.sau.com.au/forums/topic/346495-sau-30/page/22/#findComment-5692917
Latest list
- Signature/Profile sizes not being “scaled” correctly:
Eg below. You can see the large pic goes under the page skin, this occurs fairly often
Profile: http://www.skylinesaustralia.com/forums/user/42272-don-dada/
- Forum Server/System clock is out by 1hr. Posts made @ 5pm, say 4pm. Its screwing with the "latest posts" feature I think.
- Trader rating viewable from threads
- SA Club user bars (Exec are fine, Club are not working)
- Remove reputation system
- “Report Post” button does not work, spits out error
- 10 post restriction before PM, has been removed. Needs to be reinstated. Already had spammers attacking the forum.
- Signature size limits not working
- View new content is not in sync/ordered at all. Sometimes the "new" stuff on page 1 can be 2-4 days old.
C is having a look over the next few days.
Signature/Profile resize issue:
Admin to manually remove users if we come across it. No simple way to fix otherwise.
Forum/Server clock:
Disable "DST", and the problem will go away for now. Not sure why its causing problems with "DST Enabled"
Trader Rating viewable:
Coming. Christian is working on it this week
Remove reputation system:
Done
Call has been logged with IPB about this.
To be fixed. Setting removed during upgrade
C & I are in discussions. We will work it out lock it down.
This should be ok? It's working fine for me.
Thanks to Christian for all the work. He's flat out with life away from SAU so I'm doing the updating for him.
He is working on the leftover issues. Slowly but surely.
-Ash
https://www.sau.com.au/forums/topic/346495-sau-30/page/22/#findComment-5713769
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
Have you thought about organising the classifieds by state?
would like to bump this
Just remembered the survey and how i suggested the Carsales type search for the classifieds/cars for sale.
A lot of people also liked the idea and i remmember R31Nismoid said that they were going to do this.
If a.carsales type search thing is too much at least get them divided by States,or make the seller put [NSW] or [QLD] because there have been numerous times i have seen something awsome, to then go on to find out that its from VIC or SA
https://www.sau.com.au/forums/topic/346495-sau-30/page/22/#findComment-5975308
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
