Trent i dont, i didnt feel comfortable asking you for any more help as i understand your a buisness. Im assuming cause i dont have the software that i probly cant do this myself? Im more than happy to send the power FC to you and pay you if you are willing to help out? also if you could leave the basic rb26 map in it for me? as it currently has a tune for 260kw for a big single and 720cc injectors. the 26 going in will be stock for 6 months or so. Pm me if you can help out so we can sort out some payment. Wish i was closer to you id just drop the bloody car off to you and be done with it.
if its going back to stock a simple DATA INIT will load the default maps, AFM ramps and all the settings
obviously you will loose your current tune if you do this, but thats the sure fire way
or do you just need to revert to stock AFM ramps and keep everything else modified as-is?
its a 5 minute task in datlaogit to load the stock AFM ramps
Have a look in the folder that you installed FC Edit universal and you will see there is a bunch of maps that get installed with it. There is an R34 GTR RB26 v8.0 something map there as well. You can use the software to open the map offline and get the data that you need that way. All the GTR maf sensors have the same scale so using the R34 map for reference will be fine.
Edited by GTRNUR
  • Like 2
where are yo located?
i only ask as i am in and out atm. It would take 5mins to make something up map wise and would be happy to do it. how soon could you get it to me?
the fc datalogit base map for the rb26 is based on what octane fuel?
  On 14/12/2010 at 7:30 PM, DVS32R said:
Loading the base map still isnt goin to be ideal. Needs to have a decent tune in it.
+1
The base maps are enough to get your sensor calibrations correct and to drive off boost, but you certainly couldnt drive it on boost.
One other thought... If your going to use twin GTR maf sensors on an ecu with only one MAF sensor input you are going to have a tune stability issue. There is always some difference between the output voltages of both sensors.
The GTR ecu uses a mathmatical calculation that adds the two voltages (maf sensor values) together to work out the actual airflow. You can not do this with the RB20 pfc so the active load point will be off on occasion by at least 1-2 load cells.
Tieing the two maf output signals together will not work. Their values must be read independantly and then processed. Your only option will be to use a single maf sensor, and have a single air input path to the engine.
Edited by GTRNUR
  • Like 1
i was always planning to run the standard ecu, i just read something trent posted that i thought opened my options up a bit. if that much of a problem i will just run the stock ecu.
I was always planning to have it tuned after the power fc install. just assumed it wouldnt run with rb20 tune it... thus asking for the stock 26 map
ive dioded them up in the past on 1 car, not ideal but from a tune and driveability perspective you would never know. maybe i got lucky but as long as the afm curve is smooth it should be ok.
other option is to run one z32 in the cooler pipe.
Cheers guys. I knew something was different about the 34R PFC, just couldn't quite remember what haha.
Also, worth paying that little bit extra for the new PFC and EL hand controller? Will that fix the missfire that the 32Rs get with the PFC?
  On 16/12/2010 at 1:41 AM, paulr33 said:
and the physical loom plug is different, so even if you decide to be super crazy and pin swap, the physical plugs are different
nah they are the same.
PFC negates nats
and cas wires need swapping.
EL Hand controller is the best marketing rort since since Y2k compliant calculators..... i hate them.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
