  • 3 weeks later...
So how is everyones cars coming along? I've made a lot of changes to my car in the search for speed.
The latest update is fitting 18x10.5in TE37 SL's under my little GTSt. I'll be running 265 tyres all round to try and handle the new grunt from an RB25.
For those that are interested. Here is my build thread
i had a mate that was keen to drive at SL but aparently the entries were filled in hours.
never mind.
its good to see a motorsport even filling the openings.
Same. was hoping to have the car ready in about another month but given the entry list filled in hours we were way off beam.
Will still spectate though. Awesome event.
My god! Is that your road car or a second shell? Either way that is cooool. They are such good things in basic tune there seems to be a lack of seriously gutted and modded examples around! Real curious to know how much of their weight is all the doo-dahs electric things and how much is simple meat in the chassis?!?!
thats my second car, a JDM we picked up cheap.
we cant confidently dissect the wiring loom which is enormous and heavy, nor delete any computers. the essential components of chasis engine and tranny arent light.
hope to get down to 1500kg depending on cage. stock is about 1730kg
^^^^^ that's the experience we had when building Giant's too..... Anything we could actually remove didn't weigh anything, and the things we though we could get away with removing sent it into shock. :)
The body itself is extremely strong and stiff, and are built quite different to anything I've seen.
So for once I paid attention to all the Face book spam Superlap sends out lol
http://www.worldtimeattack.com/index.php/open-class-avo-turboworld-vl-commodore/
Reckon It will do any good?
Will be fast in a straight line...but it may take flight by the end of the main straigh
GT42 on a 'circuit build'. Yeah nice one!
Same thing I thought incidentally with 600rwkw dyno pony...
Put a GT35 on it, then there would be interesting... If you can keep it pointed in the general direction of forward of course :D
It will have weight advantage on it's side though to be fair. It's a SL or similar so IIRC they are around 1250-1280 stock which isn't bad. Final weight would be interesting with the heavy Ford 9" but reduced fuel tank etc.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
