The TD06H and 12cm combo would not be an all out performer in terms of response..
I have emailed Kando advising them I recommend an open-rear internal gate T3 10cm rear housing for their turbos. He seemed to like the idea, but I would not recommend you hold your breath.
TD06SL2-20G with 8cm housing is a known good thing on an RB20.
Roy has used a TD06-20G to make 260rwkw. The SL2 wheel is cropped variant so is a little lighter and produces a little more power. Roy noted earlier than he saw little difference between a couple of variants yet I believe there could have been more variables to consider.
SR20s generally run an 8cm SL2 20G and produce good results. While I think an SR is a better flowing motor than an RB (especially a 20), I think the RB20 will still produce a good result for the said option.
8cm housings can be had with both 3 bolt trust style housings OR silvia specific T518Z housings. Be it myself I would be buying a TD05H-18G with T518Z housing, internal gate and running a T3 to T2 adapter on the RB20 with a custom dump pipe. I think that would give 240rwkw with some real rip.
Roy has used a TD06-20G to make 260rwkw ... SR20s generally run an 8cm SL2 20G and produce good results. While I think an SR is a better flowing motor than an RB (especially a 20), I think the RB20 will still produce a good result for the said option.
I've never seen a bone stock internal SR20DET make 260+kw on pump fuel?! From my experience, even calling an SR20 better flowing than an RB20 is quite a stretch, let alone RBs in general. Using how SR20s go with a particular turbo would more accurately be what minimum power figure to expect with an RB20, but also bear in mind RB20s low down/midrange tend to be lazier for a given peak power than an SR20.
RB20 will happily spin all day every day to 8000+rpm in stock form... See how many times you can do that in a SR :)
You may be a few hundred rpm back down low but 1000+rpm up top
could post around 20 or so 280-300rwkw graphs of unopened sr's. Peak power between rb20 and sr20 is generally the same but we need to run more boost to get it... rb20 is also lazier onto boost but you have the extra rpm to use it... just need to wind in more boost to keep the numbers climbing
Thats interesting, with completely stock engines (including cams etc) the SR20s I have seen here seem to usually hit a wall at around 220kw or so on 98 if you are going to be sensible about boost while RB20s will happily venture past 250kw. Psi for psi the RB20s usually seem to have it (ie, outright engine flow). I am more curious about how my flatmates S14 track car will go, now - I had assumed we would need E85 and a healthy dose of boost to give it a little madness.
damnit posted wrong one. >_<
meant this one..
Kinugawa Turbocharger 3" Nissan RB25DET R33 TD06H-20G
http://www.ebay.com....=item415a2b0948
what power you after? i've never used one... but cant imagine it being a dog. I have however used a few internal gate l2 variants and they sucked hard.
yeah I,ve been told to go external sl2..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290575800499&ssPageName=STRK:MEWAX:IT
dunno 250-280 with boost by 3500
cant find any dynos at all on 25s though just a few comments saying they,re ok. and awesome on rb20s..
and a couple of old dynos that looked at bit slow onto power..
Sucked in what way? Please elaborate as me and Arthur are both considering venturing down the TD06SL2 20G 10cm road with our 2.5s
Also, Lith, NS.com has quite a few upper 200 SL2 powered SR20s noting minimal modifications. Roy has seen 260 out of his camed example RB20 and seems to be searching HARD for more. There is also very limited example of 20g comps doing more than that on RB25s on this forum. Youtube exhibits Jap 20g SR's and 1JZ's at 400ps on hub dynos. I will note that the said SR's dont plot any worse than 300kw RB25.
Anyway, this isnt SR20forum.com so forget I mentioned it and no hard feelings about my fabled SR you will probably never see :P
hi trent, yeah if you could email the dyno sheets to me that would be awsome. send them to [email protected] . thanks. ill be ringing you soo to bring the car back in, ive done some more work on some of the things we talked about, fixed the top pipe(moved it away from the turbo), sort out injectors, ive gone up to a permaseal MLS exhaust gasket, ARP exhaust studs, getting the broken stud sorted, im also moving the AFM into the cooler piping, and going to run 4" into the turbo. still hunting down some rims... 2 many options, so this time round when i bring it in, i think we will look at maybe hitting up 22psi? if you happy to tune it up to that and hopefully we can make a decent improvement, up around 280rwkw would be nice :D. Also, do you think i should look at a bigger fuel pump? i have a walbro 255l/h atm, i was thinking about changing to a dual entry fuel rail, and running a 330l/h fuel pump and rising rate regulator and going up to 800cc injectors. do you think its necessary for the power im aiming at? or is what ive got sufficient.
cheers.
Got mine tuned today :)
t67dyno.jpg?t=1308909591
t67boost.jpg?t=1308909571
t67r.jpg?t=1307875616
333kw
More in it but settled here due to injectors near max and valve springs getting loose up top.
Gotta take it for a decent drive before i say too much about how it drives and if i will push for more. Sounds CRAZY!!!! on boost :)
t67-25g
6boost
tial 44mm
freedy plenum
z32 in cooler piping
power FC
profec B II
740cc highflowed stock injectors
bosch 044
3" exhaust
Adjustable EX cam gear
exceedy 5 puk clutch (gonna have to get a twin plate i think!!)
E85 (trent tested it at E65) springvale stuff
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
