  Quote
I've wondered that myself - was hoping to update the post but you guys already got there, the fin was bent and the owner tried to straighten it, but broke it off.
ROFLCOPTER !?!?!?! That is all.
Edited by OMY31T
  On 11/07/2011 at 5:45 AM, SimonR32 said:
I have never seen a turbo have that kind of damage from hitting a compressor housing, they normally just wear down the wheels... Have seen a lot of turbos like that which have eaten bolts/stones etc. so my question is what did it eat?
This.
  On 11/07/2011 at 5:49 AM, Rolls said:
That looks more like something got through the filter, like a loose bolt or something! I would be pulling the entire intake assembly out to look for it imo.
I had a turbo where the housing and compressor made love, it still boosted but it sounded like a jet engine, probably the loudest whining noise I've ever heard, and yeah it just ground the edges down every so slightly, didn't snap anything off.
This again, I've also had compressor meet housing and got the big jet engine whine!
Bent from something hitting it lol. Myth busted!
  On 11/07/2011 at 8:14 PM, Lithium said:
I can only go from what I am told but the owner said on inspection shaft play was enough for the compressor to touch the housing
Pretty sure that would happen if something hit it with some RPM.
Naw he said the owner snapped it trying to bend the fin back.
Either way a compressor and the housing it sits in are round, I dont see it bending the one blade by hitting the housing. Impossible.
I also dont see it being replaced under warranty either.. Might want to be careful with an evo in future lol... Considering it was also a 25G compressor I would also assume the motor wasnt factory either.. Might want to be very $$ careful in future.
  On 12/07/2011 at 12:02 AM, Princess Trozzle said:
Maybe the missing piece of fin was enough imbalance to wear the bearing out and give it shaft play?
Almost certainly, but something hitting it, bending fin would be enough to put the bearing out anyway and cause it to eat the housing.
I think as a precaution he should pull intercooler and associated piping out, maybe an hour or twos work at most.
Edited by Rolls
  On 12/07/2011 at 2:18 AM, SimonR32 said:
Is he going to replace it with another one? Like someone said, I doubt they would do warranty but they do sell the comressor wheels I believe...
What rear housing was it as well?
It was the SL2 25G item they make for the evo.
Evo 10.5cm twin scroll housing.
  • 1 month later...
so is one of these a viable upgrade instead of highflowing the stock turbo?
which one would i be looking at to safely see the limits of the stock injectors and afm on an rb25 neo?
how "bolt on" are they (need a new dump pipe probably?)
if your sticking with stock injectors and afm probably best off with a highflow as the good kandos are external gate..That said, Im currently swapping out my hiflow for a kando,,you want it..lol..will easy make 220kw on 14psi which is about the limit of stock injectors/afm..speak to Tangles he has much the same turbo on his wagon and loves it
These days it seems increasingly hard to beat a hypergear turbo. These SS turbos are nuts.
The kando's are actually better for more specific applications, like the T67 for big power like what Simon has shown. The 20g is yet to make its mark with anyone, we are still waiting on results from a couple of members (previously including me). Jap dynos have shown 12cm 20g's to crank close to 300kw and stand up stronger than a 3071.. Now we are working with 10cm housings which really have no restriction in seeing 300kw, so the results should be interesting. Certain well regarded tuners have also shown interest in results from the combo, it should be good.
Downside is you need a gate, whereas with HG its all bolt on. I think there will always be tradeoffs between the two, and Stao is limited by the internal gate.. Yet if working on a budget they are both viable, however if stealth fitment is a desired option, the tradeoff (expected to be small) to a HG would be worth it.
only reason I went for a Kando was to do something a little different, seems like everyone has a HG turbo these days..
Im not expecting 300kws though, 250-260 maybe close 300 if I e85 it.. Hareys latest HG result looks good though :yes:
have anyone here tried this?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Nissan-RB25DET-R33-TD06H-20G-/270789860335?pt=AU_Car_Parts_Accessories&hash=item3f0c555bef
would the 12cm be too laggy on a RB25 NEO?
looking for a unit that can be low mounted as i want to avoid the high mount path.
also cant tell the difference between the two apart from the $200 price difference?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-TD06H-20G-12cm-T3-RB25DET-/280720132071?pt=AU_Car_Parts_Accessories&hash=item415c3947e7
target goal is anywhere from 290-300 (more is a bonus) i believe the t67 that simon has would be too laggy for me, so the TD06 would be ideal.
RB25DET NEO
built bottom end
has all supporting mods already.
PULP only, no E85 here
currently running a twin turbo setup but looking for more power and just weighing up costs for upgrading twins VS single big low mount. (So far the low mount ends up cheaper but it is for the turbo to be high mounted which im trying to avoid)
ideally i would like this one but not sure if it'll fit in low mount position?
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-TD06SL2-20G-w-T3-V-Band-Housing-/290598627474?pt=AU_Car_Parts_Accessories&hash=item43a9072892
