If the motor is happy revving there then I dont see why not. The torque and power character of the setup would influence the load on the motor, there is no denying that. It just might be as happy spinning to 8 as a different setup would be spinning to 7.
The forces created by an identical stroke/bore motor revving to those speeds is identical if all the same parts are used, the torque is obviously different though.
I guess what I was getting at is 8.5k is getting very close to the limit where stock rod bolts etc let go if held there for extended periods of time.
Edited by Rolls
my r33 will be going back into trent(status) soon, hopefully before christmas. my t67-25g setup has been proving very good, no issues yet except for my gearbox. trent, if you read this :P the gearbox shit the tin 2 weeks after the dyno runs so im going to guess it was slipping when tuned, and also the converter is a bit spongy and needs a rebuild(checked by knox automatics). ive been told the solenoids are fkd, the clutch drum for 3rd/over drive is worn out, and the band needs replacing haha. Anyway, i have just bought myself a fully manualised ford c4 street strip box brand new from rocket to go into the car, along with a 3000 stall converter, and a b & m megashifter. i have changed i/c the pipework again since the last tune(only made 255rwkw) and planning on going 4" inlet and moving the afm into the intercooler pipe. ive also heat wrapped the exhaust, sorted out the manifold flex issue and bought a turbo blanket. hopefully this time round, upping the boost to around 20-22psi i can make the 300rwkw i was hoping for.
looking forward to your results.
what other mods do you have?
inj/manifold/gate/ etc.
Goodluck with the C4 man!
My brother uses one in his Sigma but its a bit rough for my liking.. Not a brand new rebuilt job just a used one with a stally and shift kit.
Personally I would have gone for a 4L60 (turbo700) but thats just because im scared of hard shifts lol.
How much did the prebuilt C4 set you back and rekon it would be any good for circuit work or drag only? Shift quality I mean.
if you look back around pages 25-30 of this thread u can see my original build. but yeah, all suporting mods, 700cc inj, walbro 255lph pump, stock intake(this is for testing atm, no-one else has done a setup with the stock plenum and this turbo as far as i know), XSpower highmount - wouldnt suggest these, on a hot run, the manifold buckled and needed extra bracing, umm power fc,3" mandrel stainless exhuast all custom made, z32 afm, blitz suspower pod, 44mm gate, turbosmart plumback bov etc etc. i might change the injectors before a re-tune aswell, they are only flowed stock injectors and i dont know how good they are.
cant say how much i paid for the gearbox ;), but you wouldnt get change from 5k, but it depends on what version you buy, there is 3 of them.
i will put it back on the dyno with the manifold its got for now, the gearbox has kinda chewed up the funds i had ready for buying engine some nice spool internal engine parts, and replacing things i had problems with haha. but i will be changing to a 6boost in future, they are proven items and worth the extra cash. the external gate im not sure what brand, i bought it from the USA for about $150 aus + post, and surpriginly, ive had no boost creep and it holds shut until right on 17 psi, so its doing its job none the less, although im taking the 17 pound spring out, and putting in a 12 psi and going to run a dual stage controller so i can turn it down on the street.
Edited by OMY31T
Running that little boost will test out the wastegate's capabilities
certainly will, wether or not i run as low as 12psi im not sure of, being 44, it should be capable of running as little as 15psi, i just dont want to be running a min of 17 all the time and up to a max of say 22, id rather wind it back to a tidy 220rwkw for day to day driving if i can.
Is that on a stock JZ zeb??
my gate came with 7 different springs rated up to 25psi..
thinking I'll just get target my boost with springs and not worry about any controller..is this a good idea??
what are the disadvantages (if any) of not running a boost controller, apart from not being adjustable on the fly...
bah,, pansy...my BW setup will have a 2 bar spring in the gate lol
whats the point of having 2 bar on the street? roads are not made for racing, nor good handling, ill keep my 300+rwkw for the strip.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
