Wait and see what his new housing looks like...
I wouldnt get one of the housings that has the little 3 bolt outlet behind the turbine..
You would want the rear of the turbo to be all open so the WG flow path doesnt interrupt the turbines path. Ive previously emailed him about that and I think they are working on the replacement now.
Iv recently bought one of these turbos td06h-20g going on a rb20 I had mine made custom as i needed the the 8 cm housing no extra charge and came with all fittings and braided lines. With the waste gate you can just cut the welds and tap the bung out then plumb it in I was thinking about it.
Thanks for that. I did send him an email back asking if there are any negatives to the turbo he is offering so we'll see if he's honest :P
Just out of curiosity how much sooner do you think the TD05 would spool over the TD06? Do you think it'd be worth it?
It's hard to find any rb20 TD05 results on the internet. I haven't had any luck finding any apart from a few vids but no figures.
Edited by L0Ki
i asked around everywhere and in the br20 dyno results there was a 20 with a tdo5 only made just over 220 i think and seemed like full boost was around 3600rpm so for 400 more rpm you can have 260+ with the td06h-20g on a 20 all depends on your power goels and if you dont mind waiting to have your neck snaped haha
Your best option in my opinion is a td06l2
I would go the td06h I'm going on the td06l2 with 10cm housing on a 25 so a 8cm housing would be killer on a 20
I have tried both the 10cm and 8cm housing on an RB20 and the 8cm housing is definitely the way to go. That said I suspect a TD05h-18G would be a better bet. A friend had a TD05-20G and it was pretty rubbish. The little TD05 exhaust wheel loses some of its response trying to spin the bigger 20G wheel.
My 2c is decide if you can live with the lag and go TD06-20G or decide to sacrifice 20-30rwkws for more point and shoot and go a TD05-18G. I am constantly on the hunt for a TD05-18G as I suspect with 20psi up it will make for a quick car, often quicker then a car with a TD06-20G
Ah Roy, I was waiting for your response, seems as though i got the idea for TD05-18G from your build thread. I think I'll be waiting untill the end of Novemeber than for my Turbo. He even said he can custom make an exhuast housing (or atleast that's what i gathered from his repsonse) on the back of it to bolt directly to the stock flange dump pipe (so there'd be no need to make a vband dump pipe) but i think its best to keep the 3" v band for better flow?
In saying that I'm pretty sure the dump i have now is 3" so wouldn't really matter if that was true. And if the power of the TD05 becomes boring for naother 750 (who knows might be cheaper in a year) you can go to the TD06, as for what i would be doing i think response would be best at this point.
When do you think a TD05-18G would hit full boost by Roy on the 20?
I personally wouldnt be too fussed about when it hits 18psi. Plus there are so many variables. Make sure you have cam gears, no restriction in the exhaust and a good tuner. It will be more responsive then the TD06-20G but the big gain will be in the transient response. The 20G spools from around 3,500rpm and hits 18psi about 500-600rpm later. The 18G may only start spooling say 3,400rpm but because the lower inertia wheels spin quicker and harder you will be seeing 18psi perhaps only 300-400rpm later meaning it gets its boogy on earlier.
If you have a std plenum and cams I expect quite often the car would be quicker then the 20G...now i dont know any of this for a fact but suspect it to be the case so I have been looking for a Trust TD05H-18G for about 18 months now :)
Roy I just want to confirm that both the 18 and 20g compressors have a 68mm OD. In actual fact so does the 16g..
Its the inducer and trim that sets them all apart.
IE the rotating mass of a td06-18g and td06-20g would be down to the last few grams.
You are right. I have copied and pasted the following into spreadsheets over the years:
18G - 50.5mm/68mm ; 55 trim (some places call it a 50 trim...can anyone confirm?)
20G - 52.6mm/68mm ; 60 trim
See the bottom two-right compressor wheels for 18G next to 20G. So not a huge difference but whilst the smaller inducer hurts cfm, it also reduces wheel mass and reduces the moment of inertia
Exhaust side, the TD05 wheel is a good wack smaller
There are two 16Gs, and the smaller wheel has a smaller OD, though the "Big" 16G is the same
There are two versions of the 16G compressor the big and small wheel. The small wheel version has a 60mm exducer and the big wheel has the 68mm exducer. Just out of interest the T517z runs the big wheel version of the 16G compressor.
With the 20G vs' 18G comparison, even though the wheels exducer sizes are the same the 20G will be trying to move a lot more air even at low shaft speeds. The drive for the moving of the extra air has to come from the turbine which will need more gas flow to achieve the same shaft and hence need higher engine rev's to gain the extra flow. This is why larger trim compressor's are less responsive than their smaller siblings.
P.S. I'll be interested to see how your kando results compare to Trust T518z results. Is there anything done to the head ie. cams etc?
Edited by D_Stirls
Finally got my TD06L2 20G 10cm put on and its awesome!
Same as stock response but better!
Now to get some things done and tuned :)
Just the results I am after! What motor is this on? And what fuel will you be running?
You can see in this video from the weekend that in 3rd gear on a couple of the slower corners I am struggling for a little bit of drive on corner exits....Winton is the reason why I want to get a TD05H-18G to try, et more poke out of the corners. Winton is the toughest circuit for the RB20 running a 20G...but it makes you really work hard to try and carry as much corner speed as possible to keep boost up it
Yeh, yeh... i know i am whoring this vid everywhere :whistling:
I miss Winton.
Looking at the vid though...its kinda hard to tell...but im sure your "laggy little rb20" is pulling harder out of those 3rd gear corners harder than my rb25 with a highflow
While it might not be swinging as hard as it can, it still seems to be pulling well
Sorry that much I knew guys, AFAIK the 16g is the 60mm and the 16g6 is the 68mm as far as model numbers go.
I think the T517Z is also a TD05-17c but I would need to look into that again.
The SR in question is an internally standard S13 SR20DE in every way. Will be running Nismo 740s, Z32, Walbro, 450mm china core, 3" tbe and a Nistune. Has been running on a factory T28 and DET tune at 11psi/183rwkw for the last 6 years so the update will be interesting. We are aiming for 250rwkw and it will be tuned at Unigroup.
Theres a guy with an SR in a E36 on youpoop that had a T517z and went to a T518z, I cant remember if he commented he lost a little response or gained a little peak yet the vise versa was unchanged.. I think it was that he lost a little response but I honestly forget. The big T518z cars i see all run 10cm rears on SR's..... Interesting concept.. I myself am dreaming of putting an Evo TS variant on mine (S15 10:1 CR SR20DE), that would be truly dangerous.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
