As far as i know most pple r doing the 6boost manifold n external gate but thats not what i want. Im keeping stock manifold, internally gated and low mount.
Go external on stock manifold better boost control
Personally I am yet to see any dyno sheet of a TD06-20G (be is TD06S or TD06L2) make +300rwkws on 98 pump fuel. I would love to see some, especially SR20 plots as those that I have found and compared to my RB20 plot have been found to be wanting....
And has anyone ran one of those internal gate housings? They look horrible for effeciency?
Give us a few weeks, over the break we will fit our KD TD06SL2-20G onto our drift car and well let everyone know how it goes. 20psi will probably be the absolute max though.
ahh what, not you too, now everybody is doin it..I dont wanna anymore :whistling:
how would this one go? http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-V-Band-450P-/280775108722?pt=AU_Car_Parts_Accessories&hash=item415f802872
rated to 650hp, so should easily achieve 300rwkw on an rb25 with good boost control, being ext gate. however sounds like it will hit full boost between 4500-5000rpm on pump 98. would that sound about right?
Same as my T67-25g just named differently :)
Yes should go over 300rwkw and full boost before 4000rpm
just took my drifter for a quick run, just roughed in a tune so i could drive it and see how everything is.
this things gonna be mental, i cant beleive how hard it ramps up onto boost and the little screamer just cracking open, i took a quick video on my phone, cooler pipe popped off so i threw phone down to make sure i could make it up my driveway, ( u will understand when you see it)
excited to get it on the dyno
LOL, Ive have had my TD06-20G for 7 years. They were rocking horse shit in Aus when i put it on because of their "Truck turbo" reputation vs the swanky BB Garrets/HKS.
They do seem to be everywhere in plague proportions these days and that because the results obviously speak for themselves :) Still...be a man and go Trust rather then Kando :)
edit...if my car as stock I would go Kando...they are gaining a great reputation in their own right
Only the first few seconds are any good. I popped the cooler pipe off mid 2nd gear. This was with maybe 3/4 throttle.
I will try and get a better vid ince its up and running. This car hasnt been driven for 2 years. I got it as a shell and built it up over 4weeks in my spare time.
ah right, damn i get confused with all the different names these things have. would you know if that thing can fit on the stock manifold?
Hey hey im getting attacked by the kando virus today and now seriously considering a kando low mount(stock manifold) 280-300rwkw STREET turbo for my neo over the Hypergear, needs to be internal gate too so no stuffing around welding an external gate, basically looking for a 3076R/ SS1PU equivalent..if anyone can point me to the correct specced kando unit and dyno graph (so many numbers n specs), i will buy him a packet of chips..:winks
such a teaser vid...how much was that at?
i have no idea what rpm, boost or afr it was at, i know its rich and safe but my tacho doesnt work atm, i forgot to look at the boost gauge, too busy trying to keep it straight
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
