Pods need to be covered. Yeah artz yours does blend in also helps your running the crossover pipe. I had mine run down becide the plenum so everything was open. My BMW build will have a front facing plenum so gate is least of my troubles. Putting jez's kando to the test tomorrow it's drift day can't wait
Wakey wakey boys.
All Geared up ready to tow to eastern creek. I borrowed a mates go pro so there should be plenty of incar footage.
I got the tacho working now so atleast we can see rpm to boost response. Dont think the car will see much below 4000 though. Maybe in and around the pits.
I didnt get time to convert the speedo drive so there is still no vct. Should have that sorted before i get onto the dyno next with a 20psi tune. Then its straight to the drags to see what time and mph she can run.
If you can hide things then great. I must be lucky as my engine bay has looked like those pics since 2003 and never booked. So if your car externally is nothing flashy and your exhaust is quiet then there is surely a good chance you will never be asked to pop the bonnet
I have more or less gotten away with murder also when my cars have not been overly loud and have had respectable rims on them etc.
Cheap looking oversize rims and very loud exhausts will get u screwed regarless of how normal your car is. A well kept respectable car will go unnoticed in terms of them being total pricks. Then again it depends what your caught for too.
I love this thread. I wish I had another 6 so I can run a Kando... I think im better off with a stock position turbo on the SR though, good work to all the guys with nice Kandos on their RBs.
  On 21/12/2011 at 11:24 PM, zebra said:
Ditch the turbos and chuck a dirty chev in the thing....its what I am doing lol
why ditch the turbo when you could buy another one and run twin turbos on the dirty chev
Zeeb I have an LS if you are looking, VT2 clubsport kitup with box etc.
Some of you have me on FB, youve seen my photos. Car is mostly done, not going back now :P SR all the way.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
