10x1.25 iirc and about 65mm long I am told
Yep. Although with a 15mm spacer I used 57mm studs and they have plenty of room, so unless you need a 20mm spacer I'd say 65mm would be a bit long. Unless the Kando flange is thicker than the HG flange, I don't know.
hmmm
will send pm in a min
not ready to buy yet
will buy one of these first
http://www.summitrac...-2046/?rtype=10
to be 100% happy on the way it fits
Your going to spend 400 bucks on a foam LS1 to see if it fits?
LOL
dude its a commondoor motor... Why not go on a common forum and look for a blown one for $50
thanks guys
ARTZ, did you use a 10/15/20mm flange spacer?
found that ARTZ used a 10mm spacer and it "just" cleared.
might go 15mm for peace of mind.
so new update part list:
10-15mm spacer (up to you what size you want to get) $30
new exhaust manifold studs & nuts x12 ea (if needed) $110~ (nissan) or generic stuff from local exhaust place ($50~) - this is optional but if you break a stud or round one, you will need to replace them but it is a good thing to replace them all anyway and is cheap insurance that your studs won't break or round.
Dori you should do a DIY thread with pics for a 20g 10cm and document your results. Itd be nice to see the bare minimum done to fit one up, and documented for all to see.
good idea,
i shall get started after the new year once i get all the parts.
cars booked in for 16th Jan.
thanks guys
10mm
jeez man i have documented nearly my whole build in here...
what would u like that i have not provided :(
BITCH!!!
Car went great at drifting yesterday.
Only issue's i had was a busted radiator from the fan coming in contact (.5mm contact) , i popped the cooler pipe off twice. And i need a tighter diff centre. The GTR one just kept going open.
Other than that was a great day out. This turbo is very nice to drive with. On song hard by 4000rpm all the way to limiter at 7400. I will definately be fixing up the vct and tuning it to 18psi. At the moment with no boost controller and a tiny 35mm turbosmart gate it starts at 11psi and climbs to 17 by redline, starts getting crazy at 17.
I'll post up some incar vids once i get them off the GoPro
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
