Ok guys heres 1 from the go pro. Cracked 4th gear skando's down the straight. Next time ill have the camera a littke bit lower soit can see out of the window better
If it doesnt embed can some one help with it.
[url="
[/url]
[url="
%5B/quote%5D
Nice driving mate :)
Even when you just cruise out of the pit area you can tell that turbo gives the RB lots of low down zing. Very very nice.
I tried to embed the video but it didnt work, it seems simple enough but there must be a trick to it..
You would want this part of the URL:
http://www.youtube.com/watch?v=vHj1yVLbPfw
And what you would have to embed it would look like this:
[video]http://www.youtube.com/watch?v=vHj1yVLbPfw[/video]
Also it appears that simply putting in the URL above with no video tags works too:
Almost thinking of putting one of these on the 2.8 im building. Do they make something suitable for a greddy manifold? im not too sure if the flange is the same as a t4, i may have heard the bolt spacing is a little different.
Haha dude this car is built at home. That includes a by eye wheel alignment.
I honestly dont want to get a wheel alignment and do other mods because it handled exactly how i like.
But i ordered the gate and extra lock spacers so i have to get it done before wakefield on the 8th.
Im hoping the 44mm gate will do what i need even with a 38mm pipe from the manifold
No need for wheel alignment, jus undo the bolts from the hub and align the s/wheel till its straight or close to centre and rebolt back to hub lol
Hope it all goes well for ya. But by the looks of things, it will be a killer once boost is set up properly and on a small budget as well, good work mate.
What flange is on your greddy manifold? If its T4 then no.
T3 or 3 bolt then yes.
T67 10cm would be nice on the 2.8, be sure of how much power ur chasing then pick the turbo to suit. Dont concern yourself with picking one to suit your manifold, it doesnt work like that.
i know the power i want, but its the mani thats concerning me as if it dont fit then ill stick with the trust turbo. Use what i have available to me for now as i am thinking of going 6boob and an efr down the track when they sort the delivery issues with them out.
U guys post up dyno graphs too ok, dori's the next one i guess? I just hope these td06sl2-20gs are responsive- im using the benchmark gained from ss series turbos:
80rwkw@3000rpms and 180-200rwkw@4000rpms
But i guess how these turbos FEEL as in kick to the nuts is very different to a dyno graph...so thats gotta be the deciding factor--- i like a good hard kick to my nuts when it comes and lots low down snappiness
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
