Now lets see them do a billet 16g and whack it on a TD05H rear end.
I find it strange now that we had always discussed the TD05H and 20g being a mismatch, but FP are using TD05H rears with their HTA compressors which are meant to outflow the 20g - thoughts?
I am considering buying an FP Green with the 44mm WG outlet on the evo 3 style exhaust housing. Then order an SR-MHI 6boob and go spastic
heres some piccys for you to have a gawk at... :woot:
how she sits..
I gave the intake pipe a scrub, then painted it black.. :ninja:
And the dumps, dumps into a twin HKS pipe, Scotty doesnt like my design, he wanted to build me a whole pipe but i reckon it will work alright,
if it doesnt I guess he will get his way .. :dry:
some things I have wondered should I have done differently...maybe 3.5 inch dump..and tempted to just stick a 4 inch intake pipe with pod as well...not sure if there is much to be gained though
Mines all ready to go..all I need is a silicon joiner for the turbo outlet (which is on its way) and a bung for an unwanted hole in my fuel rail...then put it all together properly..everything has been test fitted..
Scotty likes to lobster, I like to let him.....Screamer is close to the dump, maybe I should poke it through the bonnet :P
I need to plug my adaptronic in and attempt to rough tune it..but this can be done on my laptop..then hopefully I can fire it up this weekend :thumbsup:
3" is plenty with a venting gate, mine is only 3" and handles a lot of power. 4" intake isn't really needed, just make sure you have a good K&N 3" filter :thumbsup:
screamer looks pretty close to the dump, might just be the angle of the photo tho.
And? Doesn't really matter :)
Finger crossed for good results ARTZ, E85 or BP98? Who is tuning?
Also don't skimp on the graphs, we want boost, torque, afr and power :banana:
Edited by SimonR32
^^^LOL you build it on a poor man with kids budget and get back to me on that....
Yeah i forget the gate venting seperatly..should be fine
E85 or BP98 is the only choice I have to make actually...cant make up my mind on that..both a are plentiful but I do like to go for long drives..
Plus if I tune for 98 I still have something to look forward to later..But yeah, really undecided still..
Trents gunna tune it for me..
Don't u have a data Logit thing? Get Trent to do tunes for both e85 and bp98!!
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
