Artz has convinced me to go highmount, pointed out a few things i hadnt thought of etc.
Im in Bunbury WA, and there isnt to many fabricators down here who like to do anything to "out of the ordinary"
So will hopefully start getting it all together soon.
All the good boilies in bunbury I know from martins and kordt get worked to the bone so they tend not to do cashies but let me know if you get stuck and I will see if they are keen.
Hahaha yep.
Got some great results but car has really bad comp surge coming onto boost. Tried a few things but 11:55pm finish was enough for me last night.
Before we touch the tune up again we need to get the vtc working.
And sort out why it comp surges so drastically on higher boost at low rpm. Hammers after that
Sounds awesome!!! Everyone loves a bit of gate :thumbsup:
Bet your glad you were forced to take it in early now eh? Makes up for the weekends bad luck :P
What is it making? Close to expectations?
Better than he expected once we opened up to screamer. When it was plumbed in it was limited at 250ish kw.
Needs a bigger pipe outletting from gate
Haha AWESOME! i thought the goal was conservative :thumbsup:
I actually thought running a screamer had a negative affect for some reason... Thoughts??
BIG THANKS TO DVS JEZ & BSA for all their work! highly recommended to anyone in NSW for tuning and fabrication stuff, they'll sort you out :thumbsup:
it was a late night but i was very happy with the results, didnt get home until 2am but was well worth the drive!
for some reason, it wasn't liking 21psi and it was surging, gonna try a anti-surge front cover and go back for more, as stated by Jez, sort out the VCT and aim for more. it definitely hammers on the road >_<
PS: plumped up gate = POO
MATT; open up that screamer!
Hahaha Ill drop my wheels off to Craved Coatings one weekend soon and give you a call to see if i can get a run with you so motivate me a bit more :banana:
That looks like it comes on hard!!! And impressive result considering the boost, BEST thing you did was take it to a decent tuner, your last guy will get the flick from now on i hope? :glare:
Good result mate! :yes:
Not sure on bigger pipe as it fitted the tial vband very tight can only try a different merge style I think
:cheers:
for some reason, it wasn't liking 21psi and it was surging, gonna try a anti-surge front cover and go back for more, as stated by Jez, sort out the VCT and aim for more. it definitely hammers on the road pinch.gif
FAAAAARRRK THAT MAN...thats freakin awesome, I thought you might struggle to make 270rwkw, man that is a killer result! ! There is no way I'm going a HG or Garret now, it does hammer on the road right?? ! ! ! Big kudos to you guys man.........:cheers: :cheers:
PS - thats with a screamer not plumbed back hey - bit worried there..
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
