My rear housing is v-band to the centre cartridge while yours is bolted.... I think that is the difference! Looks like that is the difference between 8cm and 10cm by browsing ebay. What did you order?
Looks like you're almost ready for a tune?
Tune soon & ordered a 10cm...... checked ebay but both seem same, pics and all.
Asked if any part number or casting difference's, Eiji answer is Both turbine housing looks similar, The difference is on scroll area.
Anyone got real-life pics of kando 8cm T3 rear housing?
I've got one here waiting to go on. I'll get it from the shed tomorrow and bang up a pic. But from memory it looks like my 8cm T3.
IMHO You can definitely see that the 8cm is narrower, i think OP (of this issue) will be able to work it out from there
Maybe if someone can take pics of a 10cm if its not on already?
I tend to disagree, I asked that prior to ordering and they said that the TD07 comp cover to suit a 25G was larger then a TD06 cover to suit a 25g. not saying your wrong, but maybe the seller is misguided. But I'm not convinced that he is.
Edited by urtwhistle
Hey Simon have you got an ETA on the re-tune with cams lol? Im gonna be swapping in some new valve springs soon so if the cams work out for you I may as well slap a pair in while i got the rockers off...
Hey f**k you... Tune your billet wheel first haha
Probably a month if I'm honest, Sean at Allstar is away for about 3 weeks... Might be able to borrow the dyno before then though but I've got a fair bit of work to do to the car as well...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
