Hes taking the piss.
At least someone got it..... :cheers:
As for my car, grabbed a drum of E85 and went for a tune last week,
Before I got on the dyno I noticed my fuel pressure dropping and found a leak in the rail. Right under the TB too, tired to fix it but no luck..
In the meantime get a message that Trents dyno was now busted anyway and out of commision for a week or so...
So yeah :(
Pulled the rail out and got sick of playing with rubber O-rings, so Scotty fixed it with fire :devil:
,,,still in the process of reassmbly then the wait for dyno time...
This should be kando and others titled
Its good to compare them to the others out there!! So much bang for buck compared to the $$$ i have spent, if i had researched harder i know i would have taken this path rather than the Garrett, hence my constant loitering in this thread :D
We should make a drag meet at wsid even though I don have a skyline but still running a kando td05h18g
Battle of the kinugawas
Not a bad idea, more of an excuse to see what they can do... as well as meet up and checkout the various setups!
sure thing, let us ship out cars over to WA first :P
No E85 over there, so im NOT going :domokun:
Many people just fiddle with cam gear setting and leave it where power/results suggest its working better on the assumption that the cam gear "0" position is TDC. Fact is some prefer to dial the cam in to TDC and then fiddle with the timing so that they accurately know if 2deg retarded is actually 2deg retarded, rather then just a nominal number that may not translate to TDC
So have they not replaced the turbine wheel or they are all just like that to begin with?!?
No idea... gonna have to compare it with the pics I have. At the end of the day its very dishonest of Eiji to take my money and give me something back that was in a similar condition to how he received it. He knew what I had an issue with and if they are all like that then i would not expect to be paying for a new one...
Grab a 10mm socket and pull yours off for science.
How longs shipping take with kando? I ordered my T67 2 weeks ago and still nothing, 3 days after I bought it I asked him if it was sent and he said hes still making it? Why list something on ebay if its not ready to be shipped?
Yeh the "hilarious" comment was directed at the turbine blade being supposing replaced/fixed.
Was such a pain to get him to do anything, I was emailing him every 3-4 days just to keep things moving. the turbo was sitting lost in his factory for a week before I emailed him and then he found the thing.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
