Yeh the "hilarious" comment was directed at the turbine blade being supposing replaced/fixed.
Was such a pain to get him to do anything, I was emailing him every 3-4 days just to keep things moving. the turbo was sitting lost in his factory for a week before I emailed him and then he found the thing.
I can only figure all the wheels must be like that... He can't have cleaned it and thought "she will be right" when it obviously took you time to look the first time and were going to check again.
It's a $99 (retail) part... I just can't understand the reasoning for cleaning it and giving it back when it's so cheap to replace.
Just a thought, it had several cracks before yeah? Does the new/washed one have multiple ones, I can only see one in the photo
I know it's totally irrelivent here, so just ignor it. When I was having a look at an old jet engine I looked at the turbine and it had dozens of little cracks all over it. I said to the tech that this must have been a spare parts engine. He turns to me and says , nah she'd be sweet like that and fly just fine. He went on to say people wouldnt believe that state of some things flying around.
From someone with turbo building experience, is a crack like that a fatal flaw, that will break in a matter of time? No doubt it's not good business practice what you've experienced battery.
How longs shipping take with kando? I ordered my T67 2 weeks ago and still nothing, 3 days after I bought it I asked him if it was sent and he said hes still making it? Why list something on ebay if its not ready to be shipped?
Found out my 2xTD05's were sent to "Austria" when they hadn't arrived after 3 weeks. That said, Eiji sent another set which turned up about a week later.
my bad (damn small phone screen :P)
So is it a crack or just a casting imperfection? Pretty disappoininting. Maybe I should pull apart my 18G and have a close look at it
Crack. You can see light through it if you hold on a certain angle.
I hear you Simon and I really want this Kando stuff to work out cause im a fan of bang for buck gear but it just seems like the more I deal with them the worse it gets...
It has more than 1 crack, honestly looks similar to the old one but I can't be sure. It does seem like it could be a result of the manufacturing process because the wheel is quite thin around that area but to me it just looks like a weakness and a fault waiting to happen.
The few experts i have talked to about this(without seeing the turbo) have just said flat out that its no good but i think ill have to take it down and get them to have a good look in person.
Interesting... I hope that he hasn't just f**ked you over because that would not be very professional (or good for business)
Somebody should email Eiji a link to this thread. I wonder if the amount of business he would lose would bother him.
This sort of thing is putting him into the cheap chinese basket when we previously considered Kando to be a good value item. Its now looking like their QA is dropping off something massive, and has me worried.
Whenever I consider a new setup for myself or a friend, I always consider a Kando product first. But I am not liking this change.
MAYBE, just maybe, the reason why QA seems to be dropping off is attributed to the fact Kamak are selling their own product (for more than double what Kando do).
So I took the paper weight down to a few turbo specialists, first place said "its dodgy but should be okay" I asked if they could supply and fit a new wheel they were like no we only touch our own stuff. Second place was like "No way can you run that shit it will explode" they would supply and fit a new one for around $400, $200 if i supply the wheel. Both places were obviously very bias and happy to jump on the "shit china turbo" boat...
Also compared pictures of the old one and now im pretty sure the turbine wheel has been replaced cause the cracks look different. I'd say they are all like this but whether or not its an issue is what im not sure about....
i guess currently it aint damaging perfomance as such say ure had been likt that from the start it lasted how long ?? ive got t67 aswell cant currently check to see if mines the same.
Im thinkin personally ill purchase some spares and get it rebuilt here if something goes wrong
Also i posted few pages back saying id have my results up soon well it been delayed a bit.I smashed some valves so back of with the head going metal headgasket this time looking around 300 this tune then looking for more power later down the track with e85 and water meth
Smash it back on and just run it :) The worst that can happen is you loose the rear wheel and it flys out the back of your exhaust or gets stuck in the cat
To make you feel better about it, it's not a load bearing surface (I think) and if mine is the same they can take and beating haha
Finally got a reply and this is the result
Hi Mark,
I check with our delivery department and was replied there seems problem on the T67 turbine shaft and we could balance it.
We are still trying to solve the problem.
I am still in business in korea and will be back tomorrow afternoon.
I will double check the situation for this turbo for you.
By the way, if the T67 turbine wheel can not be solved, could you accept the bearing system to TD06SL2-25G type like this ?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-10cm-V-Band-External-450P-/280868632390?pt=AU_Car_Parts_Accessories&hash=item4165133746#ht_2463wt_1185
it can go with anti-surge inlet as well.
The both wheel spec is same.
All the difference is bearing system.
Sorry for waiting and inconvenience.
Regards
Eiji Takada
jez hates anything in large quantities. boost, timing, power, you name it.
except cock. he loves cock.
Hahahahaha.
Only thing i don't like is large heads on customers :P
I love big boost just not when u bring a 10:1 comp sr20 with 98 octane and try running 16psi.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
