Great work...do the before and after graphs use the same ramp rates etc as the power curve with the cams seems to do a bit of darting around at the start and plays catch up to the std cam curve. Not doubting the result, as the cams do seem to make comfortably more grunt, just trying to understand if the cams actually allow comfortably more grunt at 3,000 & 3,500rpm which seems real surprising
Wow T67 and 3076 are pretty mirrored power wise but the T67 makes more torque, very interesting. Is the T67 something you could use in a street car? Or to laggy? The TD06 be better? I had sold my self on a TD06 but thinking T67 now for more potential in the future.
Same ramp rate. Probably different start RPM but if anything the standard cam curve should have an advantage. It's all fair and reasonable testing, we were all surprised how well it all worked.
Boost was on heaps earlier so there was a fair bit more boost between 3000-3500rpm which helps make the extra grunt.
:thumbsup: Oh well, lets hope Tomei have done their homework with the Poncams on the Rb20. I am not expecting anything near your result as franly I will be amazed if the 20G can flow any more then the 306rwkws its currently flowing
looks like the t67 would be just like the 3076 on the street , until about 3500rpm where the 67 walks away by 25~ hp :P . That sort of power in a little rwd 32 would be a handful at the best of times! 120klm/h in 5th gear would get interesting real quick!
Lol i don't intend to run a high comp motor much longer, so knowing 8cm works well on an SR means I'd rather chase the response
Status can feel free to comment now lol
Other options are 3071, 3040 and FP3073 in no particular order. FP is 2 grand worth, the others id aim to buy used under a grand or kando it
so whats goin on with the motor..?
Doing a quick rebuild on my DET. Luckily the person I sold it to determined it was to far for for his looking and brought it back.
Basic built etc. Haven't you seen FB?
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
