Yes. If you do a direct comparison on a Turbo with and without antisurge. The antisurge will have less boost response and less power all over. Because a percentage of air is always going though the antisurge slots bypassing the optimum point where the air should be going (tips of the inducer on the wheel) instead its entering from the sides.
Do you know how a spray gun works? The air flowing past the slot should promote more air to be pulled into the compressor from the surge slot using a venturi effect, this would only work up to a certain pressure obviously where the air would flow back the other way.
I would like to smoke test the front of one while its strapped down the the dyno, you should be able to see the air being sucked into the surge slots not blowing out. Perhaps someone with a map sensored car can do it for us?
The air flowing past the slot would create a vacuum in the slot and thus pull air out of the turbo blades...
Scotty not sure if your agreeing with me or not or if that comment was meant for me. But that's exactly what I'm saying, the slots will we sucking in air the whole time to Turbo isn't surging. And will spit out surging air then recirculate it back to the compressor.
I'm thinking of going the oil only 20g, mirror copy of the trust item.
Can anyone give me a reasonable against argument to make me buy the water and oil item? As ive now got a 6boost to hang the thing off, i just want less clutter and less bolts that need to be turned over and over when removing/refitting the thing and obviously less cost in getting 4AN hoses in the right length for the water.
Can anyone sway me as to why I shouldnt get the oil only item? NB all the T67s we see are oil only, while the usual 20g items are oil and water.
FYI kando also make their oil only CHRA with a smaller hub centre on the wheel and advertise it as increased flow. Does anyone want to say NAO to that? I fear larger surface area may mean slower spool. My intention is widest powerband and 270-300kw.
Can anyone explain why on the kando ebay store it says that the td07/t67 is supposed to be for a 1.8L to 3L engine
when the smaller (i think) td06 is ment for a minimum 2.5L?
I'm planning on getting a td05 or td06 for my rb20 in the near future but if the td07 is ment for smaller application i might consider it.
Robert thats not really how it works.
Please look up the member Roy and study his setup. For a long time he had a staple TD06 20G 8cm highmount RB20, hes now done a bit more like E85 and a plazmaman plenum and has hit the magic 300 mark.
First pick your power goals and then pick your turbo to suit. Kando now give the option of T3 external gate TD05H's which I think would be a good thing on the RB20.
yeah this is the turbo I'm pretty set on as it will give good power and still have decent response, I know the td06's are ment to be monsters but on the 20 the lag will just be to annoying for the street.
For a solid 240kw I would say this should hit the spot:
http://www.ebay.com....=item4165d4ffdc
plus
http://www.ebay.com....=item416678841f
Get a gate plumbed off the rear housing and hang it off the stock manifold. Beauty!
i was thinking this...but i would prefer a 3" inlet?
http://www.ebay.com....#ht_2574wt_1270
but i should fully read stuff first, your post basically gave be the best of both worlds :P
cheers mate ;)
Edited by RBert
The one I posted is the exact same turbo, except it has a 3" inlet and Ive posted the CHRA and housing separate (just because they didnt have a 3" one listed in one piece).
Realistically it doesnt matter if u get the 3" or the 2.4"...... But if u go the 2.4" ull be able to use the stock intake pipe for teh epic stealth ;) just need to make a heatshield to cover the gate.
Re your 6boost idea... a twin scroll 6boost is epic........... WHEN USED WITH A TWIN SCROLL TURBO lol. The kando range are not twin scroll, so it will do you no justice. if you want to get a twin scroll and highmount the turbo that is also a good idea, but adds another 1200+ of expense when you could get a similar result from the stock manifold and be very stealth. Imagine ripping people at the drags and looking like your running something pretty ordinary, dickkk scchhhhwwwiing.
If I had an RB20 powered car I would probably do the exact setup we are talking about. Stock manifolds, TD05H 18G with a gate off the housing. Stealthed up and stock position. Like I said 230-240kw and it would be pretty responsive/solid. Ive recently done a TD05H 18G SR20DE and that is a weapon. Faster than a 260rwkw 3076R SR20DET (both S13s).
Get the housing nice an hot, bake it in the oven or BBQ, I think Scott just used a blow torch to heat up mine. The cool it slow bury it in sand or something, I'm sure Scott will fill you in soon anyway..
In other news, where's that 300kw club :whistling:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
