I'll double check, pretty sure it was the 25g. Still seems fair responsive tho. With the cams it has a really doughy bottom end anyway and then comes on hard in the mid range.
I'll get some more details.
**edit**
*i was wrong, just confirmed it is a 20g, that's probably why it's so responsive.
I just ordered new 1200cc squirters and one of the new Walbro 416l/h in tank pump so I'll get a retune in a few weeks
Probably won't make any extra power but just will be a bit safer on injectors... Might try for 575hp so it's more than my old GTR haha
Fitted a Kamak T67-25g to my 260,000km old, internally stock 1J powered JZX90, Turbosmart 48mm progate, china manifold :(, 440cc injector and walbro pump - on the dyno today ..... its auto with a big stally, so am not expecting record breaking numbers.... will keep u updated
ah k. what brand 1200s r u gonna run?
powertune are doing 1200s drop in for the SR, supplied and fitted for $660. pretty tempting for me too, but im not sure what brand they are (fear they might be highflows of some sort).
They are high flows. They come from FiveO. They use a stock size I jector and flow then out to 1200cc. You can buy them a lot cheaper on US EBay but I still wouldn't use them. Fuel set up is something you don't want to skimp on!
Deatschwerks, same as I currently have. Straight drop in replacments for my current 750cc. They are fairly cheap as well at just over $600 delivered
In saying that does anyone want to buy my old ones (750cc low impedance GTR direct replacements)? Send me a PM
Edited by SimonR32
they are known quality though, so i wont fuss over how their made.
realistically it comes down to the process done to create them. if they have the pintle cap removed or have been drilled out then yeah.... dodgey...
but highflow can also mean internals removed and replacement parts put in. maybe the high cost of making side feed injectors is in manufacturing the bodies ETC... and you can cheaply replace the internal parts of an existing injector to create a good one (rebuild style highflow).
Im not saying this is or isnt the case... im just saying based on their track record of proven results Im willing to give them benefit of the doubt.
dumb question time but I'm sick of reading back, did 50 odd pages and don't have a clear answer.
unopened 20.
tdo6 L2 20G 8cm for around 260rwkw?will probably be getting cams at the same time. with a pfc and z32.
on same note, which sub 1k manifold?
Edited by Frenchie1001
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
