dumb question time but I'm sick of reading back, did 50 odd pages and don't have a clear answer.
unopened 20.
tdo6 L2 20G 8cm for around 260rwkw?will probably be getting cams at the same time. with a pfc and z32.
on same note, which sub 1k manifold?
If your after sub 1k it's either the cheap spec eBay Kiwi steam pipe jobbie or a quality made in adelaide Kelway steam pipe made to order.
Pics of my SR Kelway manifold are a few pages back.
unopened 20.
Save the money you are going to spend on cams and leave them std. They may improve performance but I have had experience with Apexi 260/9mm cams hurting performance and went back to std. Cam gears are a good option though
Spend the extra $100-200 and get an ETM, 6boost or Brae manifold. Tried and tested...
slippylotion...have to ask. I liked your pics...but do you have any affiliation with Kelway?...lol you are pushing them in every post. All for people vouching for good products but there is little in the way of results and arent they more expensive then 6boost etc...so well over the 1k option the OP is after?
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=393128
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=393131
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=393129
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=393130
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=393132
If your after sub 1k it's either the cheap spec eBay Kiwi steam pipe jobbie or a quality made in adelaide Kelway steam pipe made to order. Pics of my SR Kelway manifold are a few pages back.
don't really car what it is, also long as it sounds cool and my car bakes.
i googled him but didn't get any info about contacting him?
EDIT - roy, have mates who have had shocking experiences with 6boost so i want nothing to do with them, will google/get quotes from the other 2 though.
Edited by Frenchie1001
If only they were side feeders i would be onto it :(
I won't be needing my side feed 740cc hi-flowed series 2 things anymore if your interested, will be cheap cheap!
Not exactly sure how they were modified but it had something to do with a jig and grinding the ports, was told the same method is used by deatschwerks and the like?? apparently the spray pattern ends up being identical to a standard GTR injector.
PM me with a price if you want battery, Ill keep it in mind :)
ARTZ, im pretty sure i was originally telling you to get them yeah... But you concluded that you wanted something better, I more or less didnt disagree with you. I mean id rather ID's to them also, its just about simplicity and cost with a side of quality.
Bugger ! I am running one and it seems durable enough. It didn't do anything to improve performance over my old Trust manifold, (there is a little evidence that it hurt performance...so it certainly didnt improve by 300rpm like the consensus I got when researching) I know a few people running ETM and are happy with the service and quality. I have seen Brae manifolds on drift cars and the quality seems good and he is good at responding to queries as I am considering getting him to copy my old Trust manifold and going back to a 6-2-1 design vs the 6-1 6boost design
He is a mate and does quality work so I like to recommend him as a lot of other guys do for their favourite places. I did have his low mount mani before I changed to high mount. He also makes rollcages, suspension arms and braces and a heap more. Pretty much fabricates anything you want.
He is cheaper than 6 Boost and the like. I think 6 Boost SR manifold is about $990 where as Kelway is about $690. $895 for an RB manifold.
Edited by slippylotion
http://nissansilvia.com/forums/index.php?showtopic=489564&st=0 --- he builds some cool stuff!
after googling some shit, I'm leaning towards a brea. thanks for your help.
Big cams for that size turbo. I'm using HKS step 2 264 in/out 12/11.5mm lift.
They are quite large for the application, but they sound cool at idle. It was running the same cams with the standard turbo with 19psi up it.
Felt pretty strong then so I can't wait to open it up once the fuel pump is in.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
