All went well yesterday, no power figures as yet, as Allstar just did a run-in tune (7psi & 4k rev limit).
Need to do 1000k run in now. Only problem is, the car isn't registered! Has anyone got any advice as to how to go about running in an engine on an unregistered car? (without doing it on a dyno). Was thinking to just get a 48 hour movement permit, but not sure how strict they are with those...
Anyone done this before?
Also, on the topic of Kando/Kamak products. A while ago I was in search of a decent 50mm blow off valve, but couldn't really afford the price tag on a Tial or Turbosmart BOV. I searched for ages, and ended up coming to the conclusion that I could either a) just suck it up and buy an expensive item, and know that it will be quality, or b) skimp out and risk buying one of the cr@ppy brands on ebay, and hope that it does the job properly.
But then I happened to stumble across this one on ebay (which didn't turn up in any of my previous searches for some reason). I discovered that kando sells a 50mm Kamak BOV, and it is quite in-expensive;
http://www.ebay.com.au/itm/KAMAK-Turbo-Blow-Off-Valve-BOV-50mm-w-3-typs-Spring-/280913545263?pt=AU_Car_Parts_Accessories&hash=item4167c0882f
I currently have this fitted, and as of yesterday, I can say I'm quite impressed with the quality of it so far. Won't be able to fully vouch for it's quality until the car is tuned for higher power, but perhaps this is another kando product that can perform and at only a fraction of the price.
The only problem so far, is that I got a tiny bit of 'flutter' sometimes, when coming off light boost, but i'm thinking I may just need to put a weaker spring in there. Will update once I've seen how it performs under full boost conditions.
Also, when I purchased this a few months ago, it was priced at $150 inc. delivery, but it looks as though they have bumped the price to $150 + $25 delivery since.
funny this has come up now, ill be assembling in the next few weeks. not liking this run in business, i want to drop it off for the tune and bring it home as is. dont wanna pay and pay and pay again.
ill probably bed the rings, drop the oil and just thrash it happily ever after.
Do people even do 1,000km run ins these days? Most people just run them up on the dyno, Dump oil and coolant and filters and top up with new fluids and go for gold.
When I had my RB26 built its all we did.
I'm still impatiently waiting for mine to arrive .
lol my car runs dude, ill go start it now just for good measure :P wouldnt want the world to end.
im building a spare motor for it and going for a nice 270kw setup. only started about a month ago and im almost ready to start assembling the fundamentals.
can the world hold out a little longer u rekon? lol
Getting my T67-25G with Cams,44mm gate , nz manifold, Tunned this Thursday at Allstars on 98 octane as well. will post results. :yes:
just need to sort out few small issues before dyno.
- Modify (weld) my intake pipe for GFB blow of valve - i have started the car without blow off and went for lap around the block..
i also heard if you dont run blow of vale that it can damage you turbo is that right ? backpresure ? , Mafia on the forums didnt run any blow off valve..
- replace my complaence cat with a 100 cell cat ...
and it should be all ready to GO , i just hope i dont get any issues on the dyno...
:yes:
I been thinking of going T67 on NZ manifold and 44mm gate on my 34 too but realized I have to re-route my cross over intake pipe, BOV and all the associated hoses and sensors, what a headfk job..The typical U layout cooler pipes will foul any highmount turbos.. Man would have loved a T67 but too much pain, unless theres better ways..will stick with the TD06 for now
:yes:
Better to run a BOV but not essential...
Just run a cat pipe and put standard cat back in if you need to go over the pits.
Man up and DO IT Ron :P
48 hour permit... Just have to call the DPI and give them locations you are driving around to. Just find mechanics/car workshops around the metro area, get them listed on the permit and drive between them :)
Yeah, that's what we were thinking.
I wonder how strict they are with the permits though. Like, for example, If I were to list an address/workshop in Dunsborough on the permit. I may just call the DPI and ask if they would allow for a long distance drive, for the purpose of running in a rebuilt engine.
I've heard mixed advice/opinions on this, but in the end I've just decided to play it safe, and do the run-in. Probably won't do the full 1000km though.
Just do places in Perth metro area for "repairs"... Not to run in the engine
Do a T67 with a 3" front cover and low mount it.
If you check Roy's for sale thread he has a TD06H-25G that uses a 3" front cover that is normally native to the 20G we get from Kando. Thats a GENUINE TRUST item...........
If trust used the 3" cover on a 25G wheel, it cant honestly be that much worse. Maybe need a psi or 2 extra to reach the same targets. Best of both worlds mate.
I guess roughly the same response if not a TINY bit better and an easy 300kw low mounted (stock mani) on 98.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
