All went well yesterday, no power figures as yet, as Allstar just did a run-in tune (7psi & 4k rev limit).
Need to do 1000k run in now. Only problem is, the car isn't registered! Has anyone got any advice as to how to go about running in an engine on an unregistered car? (without doing it on a dyno). Was thinking to just get a 48 hour movement permit, but not sure how strict they are with those...
Anyone done this before?
Also, on the topic of Kando/Kamak products. A while ago I was in search of a decent 50mm blow off valve, but couldn't really afford the price tag on a Tial or Turbosmart BOV. I searched for ages, and ended up coming to the conclusion that I could either a) just suck it up and buy an expensive item, and know that it will be quality, or b) skimp out and risk buying one of the cr@ppy brands on ebay, and hope that it does the job properly.
But then I happened to stumble across this one on ebay (which didn't turn up in any of my previous searches for some reason). I discovered that kando sells a 50mm Kamak BOV, and it is quite in-expensive;
http://www.ebay.com.au/itm/KAMAK-Turbo-Blow-Off-Valve-BOV-50mm-w-3-typs-Spring-/280913545263?pt=AU_Car_Parts_Accessories&hash=item4167c0882f
I currently have this fitted, and as of yesterday, I can say I'm quite impressed with the quality of it so far. Won't be able to fully vouch for it's quality until the car is tuned for higher power, but perhaps this is another kando product that can perform and at only a fraction of the price.
The only problem so far, is that I got a tiny bit of 'flutter' sometimes, when coming off light boost, but i'm thinking I may just need to put a weaker spring in there. Will update once I've seen how it performs under full boost conditions.
Also, when I purchased this a few months ago, it was priced at $150 inc. delivery, but it looks as though they have bumped the price to $150 + $25 delivery since.
funny this has come up now, ill be assembling in the next few weeks. not liking this run in business, i want to drop it off for the tune and bring it home as is. dont wanna pay and pay and pay again.
ill probably bed the rings, drop the oil and just thrash it happily ever after.
Do people even do 1,000km run ins these days? Most people just run them up on the dyno, Dump oil and coolant and filters and top up with new fluids and go for gold.
When I had my RB26 built its all we did.
I'm still impatiently waiting for mine to arrive .
lol my car runs dude, ill go start it now just for good measure :P wouldnt want the world to end.
im building a spare motor for it and going for a nice 270kw setup. only started about a month ago and im almost ready to start assembling the fundamentals.
can the world hold out a little longer u rekon? lol
Getting my T67-25G with Cams,44mm gate , nz manifold, Tunned this Thursday at Allstars on 98 octane as well. will post results. :yes:
just need to sort out few small issues before dyno.
- Modify (weld) my intake pipe for GFB blow of valve - i have started the car without blow off and went for lap around the block..
i also heard if you dont run blow of vale that it can damage you turbo is that right ? backpresure ? , Mafia on the forums didnt run any blow off valve..
- replace my complaence cat with a 100 cell cat ...
and it should be all ready to GO , i just hope i dont get any issues on the dyno...
:yes:
I been thinking of going T67 on NZ manifold and 44mm gate on my 34 too but realized I have to re-route my cross over intake pipe, BOV and all the associated hoses and sensors, what a headfk job..The typical U layout cooler pipes will foul any highmount turbos.. Man would have loved a T67 but too much pain, unless theres better ways..will stick with the TD06 for now
:yes:
Better to run a BOV but not essential...
Just run a cat pipe and put standard cat back in if you need to go over the pits.
Man up and DO IT Ron :P
48 hour permit... Just have to call the DPI and give them locations you are driving around to. Just find mechanics/car workshops around the metro area, get them listed on the permit and drive between them :)
Yeah, that's what we were thinking.
I wonder how strict they are with the permits though. Like, for example, If I were to list an address/workshop in Dunsborough on the permit. I may just call the DPI and ask if they would allow for a long distance drive, for the purpose of running in a rebuilt engine.
I've heard mixed advice/opinions on this, but in the end I've just decided to play it safe, and do the run-in. Probably won't do the full 1000km though.
Just do places in Perth metro area for "repairs"... Not to run in the engine
Do a T67 with a 3" front cover and low mount it.
If you check Roy's for sale thread he has a TD06H-25G that uses a 3" front cover that is normally native to the 20G we get from Kando. Thats a GENUINE TRUST item...........
If trust used the 3" cover on a 25G wheel, it cant honestly be that much worse. Maybe need a psi or 2 extra to reach the same targets. Best of both worlds mate.
I guess roughly the same response if not a TINY bit better and an easy 300kw low mounted (stock mani) on 98.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
