3540 shaft snapped in half and the Kando cost less than just a core for the garrett.
essencially the same engine apart from new injectors, rochester 1000's and a the T67, it is spooling up heaps earlier than the 3540, around 1000-1500 rpm earlier which makes me think its the housing.
thats quite early but i think the 8cm would be even earlier.
take a few photos of the rear housing, i am fairly confident i can tell the difference. Take pics from around the flange area.
im fairly certain that a 10cm housing has more of a taper on the exit side of the T3 flange than it does on the CHRA side, whereas an 8cm has the same amount of taper from the flange on both sides and the snail shell is a little thinner.
This is my observation but im not honestly sure this is correct!
The genuine garrett .82 will be better suited. The .73 (10cm) kando housing is a tiny thing.
There are also better options available for that sort of power when talking 'responsive' and 400kw on a dirty thirty. Bare in mind a 35R is similar in size to a precision 6262.
A bush bearing PT can be had for roughly 1k delivered, and would be a hands down winner if you went for the T4 TS option. Single gate to keep costs low will still work a treat.
Finally here is a couple of pics of my turbo housing, i think it is a 10cm but it is just too small for my 25/26 with cams. We ended up getting 275RWKW out of it at 20psi on BP ultimate. It spools up to full song at 3500 and starts to drop off around 6000. It is very good to drive but we were pretty disappointed at the power output.
Simon, i suggest waiting to see how i go before getting the T67.
Worst pictures ever haha But I think it's a 10cm by the looks
In that case I can almost guarantee you something is wrong with your set up and not the turbo... These things don't drop off at high revs, we went well past 8000rpm with mine and power was still going north.
You are about 50rwkw down on where you should be... Got a graph?
Looking for a Kando for my 26/30. Has anyone got any thoughts on this? Basically a 3582r with .73 rear housing. Want to make a responsive 400 rwkw http://item.mobileweb.ebay.com.au/viewitem?itemId=120892863434
Hey Simon, I got a Kando TD06H-25g with the biggest houseing they make on my neo 25/30. It's not tuned above 5000rpm cos I need to replace my wastegate ( I'm not doing it untill my new 4wd arrives). To compare I had a Hypergear Gt3576 that made about 370rwhp on Ultimate 98 on Hyperdrive's dyno (In WA). With my rev limit set at 4500rpm I think I could safely say that the new kando turbo is massivly more powerful and massively more responsive.
I have herd of people running T67's on 3L's but I honestly reckon that it would be happier with the slightly bigger TD06H-25G.
But that all being said my car isn't fully tuned so I ahve no idea when it will stop making power.
i know nothing about the PT turbos.. just did some reading up on them.. looks to be the goods! might go with a 6262 i reckon
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
