So a 3076R 0.63 which is smaller is EVERY way can be ok on a 30DET but this is too small...
i think you are missing the point here! you are saying that the turbo is ramping too early and has no legs up top? im saying too small as in maybe they sent you thr wrong turbo!
a t67 should but upwards of 300+wkw with no issues what so ever!
Hey guys,
In a bit of a pickle, I've got a TD06-20G 12cm on my RB25 and it's a lot laggier than I expected. Although it wasn't tuned on what boost I wanted (20psi), it's only running 13.
I'm guessing that the turbo isn't in it's sweet spot and is taking it's time doing anything. I've been searching for weeks about info on the 12cm but I can't find shit (yes I have searched this thread many times!).
Has anyone run or tuned such a beast on a 25?
It made around 235kw which is decent power for the boost run I guess but yeah wasn't expecting it to have full boost around 5500rpm, any ideas?
Edited by Run-It-Hard
Hey guys,
12cm rear will add to the lag
chuck a few more pounds into it and see how it perfoms but will def be sluggish under 4k
It's out of the boat yard finally :P
Will more boost change the power curve, i.e turbo start working it's magic earlier? I was looking at two graphs somewhere in this monstrous thread and it seemed this way (same car, two sheets at diff boost levels). But yeah I'm noob with this stuff.
Hmm I wonder if that 10cm would fit.
Is it a TD06S or TD06SL2? That will change what housing you need to buy.
Either way a 20G on a RB25 with whatever rear housing should be running a 10cm.
Your 12cm is just making it doughier without benefit. Easily fixed though as mentioned.
Also, is it a T3 or genuine trust 3 bolt?
It's a TD06S and it is a T3.
Spewing eh! Ahwell I got it cheap ($600 via Ebay special). Atleast it's fixable, just a pain in the arse lol.
I wonder if Raz' 10cm rear would fit my turbo, hmmmm.
Cheers for all the help guys :)
Unfortunately it wont.
The SL2 is 61mm but the S is 65mm. Kando doesnt even sell housings for the S no more.. You are better off selling it as is to someone with a bigger motor and swapping it out for a Kando item. Im guessing its also internal gate with that abortion of a 3 bolt discharge?
Unrucky.
Alternatively, you can send it to Hypergear who will be able to machine up one of his 5 bolt Type B rear housings to make it dance.
Hey guys,
i saw trent talking about running a tdo6 (of some description) with 12cm combo on a neo...my guess is it will come on a little later but make hard power all the way to 8000rp+ and then some ...5500 does seem a little ridiculous though..vct working?
So pump it full of boost and rev it hard and hopefully you should see some good results..good for hard sliding anyway...if its a streeter/racer drop it back to 10cm...
Here you go Jez
As far as I know, it's a untouched RB25. Full boost is actually 5750rpm lol, as you can see it's a slug to drive off boost too.
I've spoken to Eiji and they do make a 10cm rear for my turbo so I'll probably get that sometime next year.
Really wasn't expecting it to be THIS laggy, live and learn I suppose.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
