yes very tempted....looks i can only gain it definately has more top end and loses nothing anywhere else :D
its asking alot of my stock manifold, though in theory i could make the same power I do now with a little less boost...
to me the theoretical limit is in absolutes, so you could still gain midrange :)
its a gamble but seems worth it for sure! And it would be a true back to back for everyone moving forward.
Aren't you simply running moire boost so jump in mid range and power kind of expected?
need to compare thin blue power line to pink line, more power with less boost. i have a feeling the exhaust manifold heaps here too.
yeah i'm a little confused too Roy, the date on the paper is same date I got mine tuned yet neither graph looks to be mine, as mine seems to fall somewhere inbetween the pink and blue....its actually closer to the pink but with a bit more boost and im topping out earlier..Im wondering if the standard manifold is helping create a little more torque in my midrange as well..
and why is Staos car 10kms slower at 6060rpm??
the times also dont match, maybe an earlier tune than my final been used or maybe my tune with a high mount got a different result I dunno......obviously I dont yet fully understand the intricacies of dyno tuning but I daresay the small differences we see are just mechanical.....i was also running a 3.5 ex and screamer at time of tune..it has all been plumbed back now..
I think its fair to say the manifold has made some difference. But, it is also fair to say Staos new wheel can definitely pump more boost and power than mine ever could as other cars with the sl2 and high mount haven't made that much power that I know of and usually die out around 20psi... the fact he is making more power even though the boost is dropping off a good 3 psi has to say something about its performance...
unfortunately I'm unemployed and going back to school, so too strapped for cash (read missus will kill me if she sees me spend money on that car) to try it atm but it would be good too do as I think it would be an improvement..got any work Stao maybe I could do some deliveries or wash and detail your car or something, cause technically a fair trade is not spending money on my car right..at least thats what I tell the wife.? :rofl:
So I want a new turbo for my RB20DET as its going to be pointless swapping my VG30 OP6 turbo onto my RB20DET-R manifold. Thinking this TD06SL2 8cm with Garrett 60-1 compressor would be a good thing. I have Nistune, Z32 AFM, GT-R injectors, unopened motor, RB20DET-R spaghetti manifold. I am thinking internal gate as space will be at a premium with the turbo placement on that manifold for tapping the exhaust housing for ex. gate, and no way in hell am I cutting up the manifold itself. I'd like to shoot for 1.2-1.5bar boost and hopefully 220-240rwkw.
Is it going to be completely useless for my application?
I was otherwise going to go for a T3/T4 60 trim Garrett with ATP's 'ultimate internal gate' (ford bolt on type)to try and replicate the GTS-R's T04E as closely as possible but the Kando seems an equally good option for a lot less money by the time you factor in all the fittings and stuff.
Thoughts?
Hell no, I ain't selling that thing ever! And yeah I'd never chop it up, no way no how. Its been suggested I weld an elbow onto an external gate housing and run a gate off that, or run a spacer with a gate pipe between turbo and manifold, but I think I'm going to run out of room in either situation there (strut tower in the first instance and engine mounts in the second), so I just want to know if I can reasonably successfully run an internal gate at that kind of power/boost level.
Edited by floody
For 220-240 and internal gate why arent you considering a hypergear?
Get him to make you an SS1PU with a 3" vband outlet on the back, or you can just get the current turbo highflowed to that spec and it will bolt straight back on.
It will be the simplest possible setup you can imagine and should shit in 220. I cant understand why its being overlooked....
Mostly because I know nothing about them, nobody I know has ever used one, but looking at the spec on their website it sounds like a good thing. That said, its more expensive than even the Garrett option I'm looking at, and almost double the cost of the Kando for the turbo and v-band gate alone. Which is fine if its twice as good?
Edited by floody
lets not get our knickers in a twist.
I dont see how a garrett could be cheaper than a HG, or how you could consider a kando to be half the price if you had read this thread all the way through. Kando VS HG is something that has been discussed on nearly half the pages in here.
A HG shouldnt cost you any more than $1,100 regardless of which model your looking at. A kando will cost $800, plus $400 for a gate, and probably another $500 to hang the gate off the housing and make a custom dump. The HG will come with the same 6 bolt dump flange you have now if you want it to and will bolt right on as an internal gate.
None of the options available can be said to be better than the other, they all have their ups and downs and you need to read the threads to familiarize yourself with them.
The Garrett I am interested in is $740USD for the bare turbo with my choice of exhaust housing, $168usd for the v-band bolt on gate; $908AUD currently. Plus an unknown amount to ship.
The Kando is $785, including a bunch of fittings, choice of wastegate actuator etc.
The Hypergear is listed on site at $1150 for the bare turbo plus $180 for the wastegate, plus shipping.
All linked in my previous post.
So on my maths, so long as the Garrett doesn't cost more than $300 to ship it should come in as cheap as or cheaper than the HG's pre-shipping cost, and no, HG's $1330 isn't double $785 but its getting close. I don't need or want the 6 bolt flange I have now, because the long tube GTS-R manifold turns the turbo almost 90° and sites it lower than the non-R cast manifolds do; no matter what I will be having a V-band dump made.
My preference is for an internal gate turbo (either cast in or bolt on gate) with a V-band outlet.
Edited by floody
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
