nice..id love a turbo v8
cheers
darren
C'mon mate, we know they don't make em like they used to. It's missing a Holley double pumper and a high rise manifold.
Beryl would not approve.
lol current thought project of mine is a 4 barrel on my 928 porsche.. just need to think of how id do the intake manifold to sit the carb.
78 model porka, may aswell get 70s tech lol
Did a retrofit with a autronic on one years back. love 928s
Do you have any notes or pics of it laying around? I am in need of inspiration.
Mine is the mechanical K-jetronic setup.. I actually got it running nicely with some tweeking but for gods sake the car feels slow compared to anything turbo.
Do slide around your loungeroom on your socks just wearing sunglasses, a shirt and some jocks?
cheers
darren
and sing to cheesy 80s tunes, yes.
actually i just bought my own home and got the keys on monday, so i will definitely be doing the above just because i can.
Its a 300 page old thread with tons of info and the same questions being asked over and over, usually with guys like me replying and not being a total prick telling people to read the thread from start to finish.
I think we are allowed a little banter.
yeah i gave up being a prick and telling people to read the thread ages ago....How you been anyway Jas...long time no see :P..
LOL yeah you know, moving house this week. bought my own place.
fun times, sir SR is on the back burner for now.
what about you? anything to add to the kando land chat thread?
turbo is making a funny whistle...haven't diagnosed it any further than it is coming form the area where the turbo is...put 40psi (from a compressor not boost :P) through the system and no hoses popped...but there is a little annoying whistle there on boost...think it might be the comp housing or something ...laziness and a fear of the unknown is stopping me from removing it for inspection....
How many K's have you done with that thing now?
I pulled mine down a few weeks ago and had the core apart, all looked good and the imperfections on the turbine wheel hadn't grown or changed..
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
