With the 12cm a bit more energy was put into trying to get it to hold boost. Didn't exhaust ourselves as I dont want to spend too much $ fiddling around when the setups are going to get swapped. Main thing is we get to see the character and idea of response and numbers. But curious that it wasn't anywhere as simple as getting the other combos to hold boost.
This is similar to what I found with the 1.06 tial. Nothing in the Turbosmart instructions worked so I had to design my own setup using the 5 port. Buggered if I would be paying a workshop to diagnose all the issues I have had so far...
Anyway, good luck with the HTA, should be a good thing on the 25.
This :whistling:
Well after some head scratching found a problem with the Turbosmart gate. Will be surprised if its the cause of the boost problem but either way the thing needs fixing as the bottom of the alloy housing is pissing air through the valve stem due to a failed o-ring. Seems to be made of rubber which has naturally hardened and failed. So in theory that would make the thing spike or run higher boost than expected but will see.
just got my rb25 tuned the other day with the td06sl2 10cm, greddy copy, 440cc injectors, aftermarket throttle body, custom low mount steampipe manifold, full 3 inch exhaust.
Car made 268 hp on 15 psi and it started to lean out on full throttle.. and this is my problem now D:
wasn't your tuner able to diagnose this on the dyno?
I can have a guess and say it was your............... wheelnuts? I mean it was on the dyno... why couldn't the tuner work it out? Its almost impossible to guess what did it without getting you to check nearly everything including the wheel nuts, but it would have taken said tuner under an hour MAX.
Argh this R32 seems very resistant to do what it should do. How was the 73HTA behaving in terms of spool compared to the other setups? It's a shame to hear it sounds like it might now get its chance in the sun due to external factors.
Very keen on this also :yes:
Nothing amazing. Nbew fuel system is about finished. Turbosmart parts arrive today. So hopefully over the weekedn get things sorted and get theh thing fully tuned on Monday. Only the 73HTA is already off :) I looked in the mirror and deep down inside I knew I wanted to run the TD06H-25G...ie a Man's Turbo :)
The 73HTA had near identical spool and looked as though it would tune up ok but ran out of fuel. I canned it as wanted to see how the gruntier 25G was going to go response wise with the smaller 10cm housing. Also want to make sure that I have the biggest dirtiest turbo I have on there to check the engien as there is possible there is a restriction somewhere in my setup that is capping power as nothing tried to date has allowed the thing to make the power of the RB20 :(
So need to rule out the fact that my kinder surprise engine isnt somehow a bit ordinary at making power. Its got good bits, Good compression, pressure. No blow by. Tunes up right...we did run out of fuel but it doesnt really make any more power at 20psi then it does at 15psi so ?!?!?!
^ ditto, but I can see where you are coming from. Shame about the resulting what-ifs, but if it spooled well and we know that it is only a few lb/min lower flowing than the 25G (~54lb/min vs ~58lb/min?) then it isn't a bad indicator.
Will see how the 10cm housing goes. If it is somewhere between teh 8cm and 12 cm (makes sense) than I will grab 40-40rwkws through the midrange which given the 25G wheel gives me the sort of power that I am after ...well not being able to put a 10cm housing on the 20G or 73HTA is a killer.
:blink: i made 267kws on pulp @ 15psi...you should be pissing in around 350hp atws...
You need more fuel? E85 Walbro pump, Bosch 1000's and ethanol in the tank... Win.
I think he has bigger issues at hand man...e85 is your answer to everything...:laugh:
stock GTR injectors yeah....invest in IDs...Nissan will love you :D
from my experience, unlike bigger turbos the SL2 doesn't get a huge improvement from e85 anyway...its great on Pulp too...18psi should see you around 280kw ish...
I agree with the above. The L2 20G is a fairly efficient item where it gets close to its maximum flow without the need of E85. Dont need to convert to ethanol to get the right power out of it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
