AH. You must have got given the non-ported version. The ported one is 34mm.
As reference my SS1PU is 29mm. Fingers crossed for Saturday.
Success - strangely it holds ~.9-1bar of boost on wastegate boost, which is more like what we expected in the first place. Mysterious, but at least it's sorted now :)
Qu O/T.
has anyone used a kando turbine housing (like the ones below) on a garrett gt30 based turbo?
http://shopping.kinugawaturbo.com/turbinehousingkinugawagarrettgt3037gt3076rgt3071rgt30rar618cm.aspx
if so, what were the results and what are your thoughts on the quality?
would you think the A/R 8cm is too small for a 2.0L 4-cyl twin-cam engine?
thanks.
Qu O/T.
thanks.
It doesnt fit the good gt30's any way 56t / 84 version is the way to go.
yes it does.
- Turbine wheel Spec : 84 Trim / 60.0 Major / 55.0 mm Exducer
- There are three types of GT3071R turbine wheel. This housing can not fit 56.5mm/trim 84 nor 56.5mm/trim 90 turbine wheel.
And this is with Link boost control turned off on the dyno, so just wastegate boost:
And an interesting update since the boost creep issue has been pretty much sorted, couldn't do 3rd gear because of lack of traction (??!!!!) on 18psi - even 4th getting a bit skatey (it's around 0 degrees here tonight)... decent spool even on 80% throttle though:
yes it does.
ahh thought it said it didnt fit the 56mm 84 version... which is the only one worth using.
  • Like 1
Interesting.. Not a fan of the 60mm 84T?
I thought the creme of the crop was the 3037 60mm 84T?
I have a feeling that IWG housing is a flanged version of the fail-whale 3 bolt one. If you remember there was a guy who hacked open his fail-whale housing to make it a proper open flanged rear end (a Jez customer) and that also failed.
I would probably do this with an EWG housing like urtwhistle, or would consider a G3 with some massive v-band outlet (IWG).
yes was concerned about that...but 830 bucks :woot: and its a 12cm so maybe it'll work a little betterer
some goose tried to convince me to put a EFR turbo on it which would be awesome but jeezuuz i can almost get a 2jz half cut for the same price...
also all the budget 7m manifolds are t4 it seems...its an NA+T so 9.something compression...only aiming for low boost and responsiveness and I would prefer IG to keep it simple , not aiming for big power just a meaty midrange and good spread...g3 could work well would prefer power from 3-6rpm
Got some tree stumps need pulling
hahahah dam iphone........... If your going for low boost I wouldn't go the TD06H like I did. I would probably stick to the ordinary TD06 so that it boosts a bit quicker. I went the billet compressor wheel too so I'm not sure what difference that made. Yeah I think it was the one you said wouldn't work hahhahaha. but then again if my memory serves me correct it has a 3" surge TD07 compressor cover not the normal ones. I can't remember, it was too many bourbons ago. All I know is that when I fix all the pipes that blow off above 20psi and fuel surge it will make more power by the feel of it.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
