does anyone here have dyno graphs of the kando td05 18g and td05 16g on an rb20? ive been searching through and getting mixed results but not too many graphs, i'm considering getting one of these turbo's and would like to compare spool times mainly so boost/rpm/power graphs are much preffered, thanks :)
Do they even sell these turbos anymore? I don't see them on their site anymore.
yep they still do, check their ebay store, and even though it doesnt have it as an option on the ebay store you can get them with a billet wheel and 9 blade turbine wheel (asked myself), im possibly getting one of these turbo's for my rb20 and just wondering what the response/power is like from people who have had one of these on their rb20
  • 4 months later...
  • 1 month later...
Hi guys! I read, read the topic, the result is some of the turbines? Price quality? Trusted by themselves? Let's say if we talk of the TD06 on RB25 neo6, 1kg every day to ride on the opening event and any blow 1.2-1.3? It is necessary to consider all these turbines? From the machine is required - town riding 300-380ls.
Sorry if something goes wrong with the wording of the proposals, as using an interpreter.
After many years i finally got around to tuning mine. RB25, TD06 20G 10cm rear, on e85 with all sorts of supporting mods. 17psi straight off the external wastegate so no more boost was added with my boost controller due to the rear brakes sticking on.
Keen to get out and drive her now thats for sure!! Will re book for more boost after the new year!! Really happy with the results.
  • Like 1
  • 4 weeks later...
I have a genuine GReddy TD06 20G, albeit the L2, and Mine also Dies off up top like yours does. Mine dies off even harder. We think it was due to having a f**ked cat. Now had 3" straight pipe exhaust.
Does show the Kando's perform similar though.
My Results were very similar... 270kw, 430nm, on 98 fuel, with stock plenum, GReddy manifold. same boost.. Would have been almost identical on e85.
post-27211-0-64464800-1390218028.jpg3
Now have 264 cams, E85, new ecu and other stuff going in.
Well done. Be good to see the outcome with more boost. ;) It'll Be a blast to drive as it is.
xpost-27211-0-64464800-1390218028.jpg.pa
Wow both are really close. Just shows that e85 does give you that little extra.
I have Tomei pon cams witch I think has helped the top end to open up a little more. Interested to see your results with the new gear going in and on E, when I have cash again ill rebook mine and update again!
  • 1 month later...
You're wanting to go with a completely different compressor wheel. A housing profiled for a 25G won't work with a 20G wheel.
Buy a complete turbo. What are you hoping to achieve with the downsize in cold side spec?
I'm just about finished my rb2530.
Im gonna get a tune for both t67 and td06 20g.
That way I can decide for myself what I like best threw the seat of my pants.
Not interested in dyno numbers. I'm interested in what I have under my foot. It's purely for street now. But I'd like to have the option of changing turbo to suit my wants and if I don't like it il change back. (I can burn money easily) but I'm not getting gt3076
  • 3 months later...
I have ran a TD06-20G with a 10cm housing and 8cm housing on an RB20. Difference in response is HUGE. No difference in power
I have ran a 12cm housing and 10cm and 8cm housing on the same TD06-20G on an RB25 and the response is light years different again. 8cm was mega punchy but fell over after 6,000rpm. The 12 cm was laggy and basically the 12cm-20G on the RB25 was the same as the RB20 with 20G and 8cm...so big step backwards.
The 10cm was the sweet middle, pulled well to redline but certainly wasnt as violently response in the 3,000rpm range as the 8cm
I quite liked the 8cm on the RB25. If my car was purely street I would have kept it as it drove like a diesel truck. But the lack of top end would have annoyed me when driving at the track
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
