I understand that when using forged pistons, oil consumption tends to be increased. I'm just wondering by how much and what is considered normal?
Also, what other factors will increase oil use? ie. Will thrashing it increase it drastically or not?
G
  • Like 1
https://www.sau.com.au/forums/topic/347968-oil-consumption-in-forged-engine/
No it shouldnt unless your making stupid horsepower or big boost 25psi up (as clearances are generally increased @ these power levels).
It should use no more than a new std rebuild.... ie nearly nothing.
Poor piston choice could also be a factor but most decent brands run nice tight tolerances if put together right
over the past month my engine has used a couple of litres of oil (forged built engine, no visible leaks). i have been told that i get pufs of oil smoke when i back off at mid to high revs and the catch can was putting out a fair bit of vapour, but is not filling up with oil and deffinately not a couple litres of it (could this be caused by E85 or is it likely other issues?). it was setup with the PCV blocked off but that has been connected again and i have noticed a significant reduction in vapour from the catch can though the oil usage is still there.
The engine is fairly noisy when cold but once up to operating temp doesnt seem any louder than the old engine was. it idles smoothly and doesnt feel like its lost any power its just started drinking oil.
do a fairly agressive leak down test on it (@ operating temp), it will tell you whats going on.
Here's one we did not long ago.
CYL COMP LEAK DOWN
1 155 10-16% @100-110psi
2 155 10-16% @100-110psi
3 155 10-16% @100-110psi
4 155 10-16% @100-110psi
5 155 10-16% @100-110psi
6 155 10-16% @100-110psi
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/index.html
CYL COMP LEAK DOWN
http://www.carcraft....ster/index.html
did a basic compression test this afternoon/evening 150-160 across the board. took the throttle body off and the intake plenum is clean with only a tiny bit of oil residue just after the throttle but thats it.
will give the leak down test a go assuming we have a tester that will do it.
it was all working fine with no real oil usage to speak of, sat in the garage defected for 9 months and now it uses heaps :/
^^ i have a customer with a mx5 that had a 1cm raduis chunk missing off the crown of a piston and it comp tested fine... comp test can be misleading.
stuck a camera down the sparkplug holes. bores still have hone marks visible, cant see any signs of damage to the piston heads.
we dont have a leak down tester that gives measurements, though we lined them all up a TDC and put ~100psi into each cyl. all cyls had a little leakage on intake and exhaust (very small amount could be heard leaking out), none of the cyls gave any bubbles in the coolant however with the oil filler cap off there was a fairly audible amount of air coming out though i am not sure how much should be leaking out from there if everything is fine.
as far as the valve guides go, i am not sure though the valve stem seals were replaced in 2008
I was going to suggest valve guide clearance and condition of stem seals also... on lift off the high vacuum can pull oil down through the seal around the valve guides.
Maybe after sitting around for so long the seals went dry and got damaged when you first started it up again???
  • 4 weeks later...
i have noticed recently with this that it only seems to use oil when running on the caltex E-Flex ethanol fuel, while running on this fuel there is a significant increase in the length of time i can hear piston slap as well. i have been switching between the two fuels recently, however i will give it a few tanks worth on just 98 and see if the oil usage continues or not.
Hmmm got same problem here,forged engine (482whp @ 24psi) 30,000km old uses 1L per 5000km serice, I was told that it's normal with forged engines and just to keep an eye on it :unsure:
P.S Also once oil reaches operating temp.(80 -90 C) oil pressure drops to 2bar when on idle( eg. waiting at the lights or cruising 2500rpm in 5th) but when I start to accelerate it goes back to 4 bar or above, should I be worried because of pressure drop and get it checked ?
Edited by 3BEPKA
that seems pretty normal to me... as oil gets hot it thins a bit and the pressures drop compared to cold start pressures
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
