I understand that when using forged pistons, oil consumption tends to be increased. I'm just wondering by how much and what is considered normal?
Also, what other factors will increase oil use? ie. Will thrashing it increase it drastically or not?
G
  • Like 1
https://www.sau.com.au/forums/topic/347968-oil-consumption-in-forged-engine/
No it shouldnt unless your making stupid horsepower or big boost 25psi up (as clearances are generally increased @ these power levels).
It should use no more than a new std rebuild.... ie nearly nothing.
Poor piston choice could also be a factor but most decent brands run nice tight tolerances if put together right
over the past month my engine has used a couple of litres of oil (forged built engine, no visible leaks). i have been told that i get pufs of oil smoke when i back off at mid to high revs and the catch can was putting out a fair bit of vapour, but is not filling up with oil and deffinately not a couple litres of it (could this be caused by E85 or is it likely other issues?). it was setup with the PCV blocked off but that has been connected again and i have noticed a significant reduction in vapour from the catch can though the oil usage is still there.
The engine is fairly noisy when cold but once up to operating temp doesnt seem any louder than the old engine was. it idles smoothly and doesnt feel like its lost any power its just started drinking oil.
do a fairly agressive leak down test on it (@ operating temp), it will tell you whats going on.
Here's one we did not long ago.
CYL COMP LEAK DOWN
1 155 10-16% @100-110psi
2 155 10-16% @100-110psi
3 155 10-16% @100-110psi
4 155 10-16% @100-110psi
5 155 10-16% @100-110psi
6 155 10-16% @100-110psi
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/index.html
CYL COMP LEAK DOWN
http://www.carcraft....ster/index.html
did a basic compression test this afternoon/evening 150-160 across the board. took the throttle body off and the intake plenum is clean with only a tiny bit of oil residue just after the throttle but thats it.
will give the leak down test a go assuming we have a tester that will do it.
it was all working fine with no real oil usage to speak of, sat in the garage defected for 9 months and now it uses heaps :/
^^ i have a customer with a mx5 that had a 1cm raduis chunk missing off the crown of a piston and it comp tested fine... comp test can be misleading.
stuck a camera down the sparkplug holes. bores still have hone marks visible, cant see any signs of damage to the piston heads.
we dont have a leak down tester that gives measurements, though we lined them all up a TDC and put ~100psi into each cyl. all cyls had a little leakage on intake and exhaust (very small amount could be heard leaking out), none of the cyls gave any bubbles in the coolant however with the oil filler cap off there was a fairly audible amount of air coming out though i am not sure how much should be leaking out from there if everything is fine.
as far as the valve guides go, i am not sure though the valve stem seals were replaced in 2008
I was going to suggest valve guide clearance and condition of stem seals also... on lift off the high vacuum can pull oil down through the seal around the valve guides.
Maybe after sitting around for so long the seals went dry and got damaged when you first started it up again???
  • 4 weeks later...
i have noticed recently with this that it only seems to use oil when running on the caltex E-Flex ethanol fuel, while running on this fuel there is a significant increase in the length of time i can hear piston slap as well. i have been switching between the two fuels recently, however i will give it a few tanks worth on just 98 and see if the oil usage continues or not.
Hmmm got same problem here,forged engine (482whp @ 24psi) 30,000km old uses 1L per 5000km serice, I was told that it's normal with forged engines and just to keep an eye on it :unsure:
P.S Also once oil reaches operating temp.(80 -90 C) oil pressure drops to 2bar when on idle( eg. waiting at the lights or cruising 2500rpm in 5th) but when I start to accelerate it goes back to 4 bar or above, should I be worried because of pressure drop and get it checked ?
Edited by 3BEPKA
that seems pretty normal to me... as oil gets hot it thins a bit and the pressures drop compared to cold start pressures
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
