hai guise, its official, im sick of my old tien stiff coils and im getting some new ones, i like stiff suspension, just not as stiff as tiens, slightly softer would be ideal, i have been considoring the BC racing sets on justjap, what are peoples recommendations?
the car is a dailey, but i like the suspension hard, just not as hard as tiens, the car dosent see trackwork.
r33gtst
cheers
https://www.sau.com.au/forums/topic/348051-recomended-choice-for-coilovers/
why not just go for a decent shock revalved to suit a decent spring, rather than go for the you beaut cheapo coilovers that have a million and one adjustability settings which no one except a proper suspension workshop with corner weighting facilities and good experience can get right...
i must ask what advantages do you actually find on a dedicated street driven, is the only reason you have them because you like a hard ride? or is it just so you can change the height? im know heaps of cars out there are daily cars with coilovers but i cant justify spending 2k (for GOOD) adjustables when the way you drive on the street will never require them. i have put the money i could have spent of adjustable coilovers into sway bars, strut bars, heaps of new bushes, giving me some mean camber and caster and rigidity. i would do the same again.
how ever each to their own
Edited by PaulosECR33
I have BC V1's that just went on my car, After a bit of adjustment and playing around Im happy with the height etc atm
There pretty good on the street, I wanted to keep the car relatively driveable so went with the V1's with 8kg front and 6kg rear spring rates
Ive only just got the car going again tonight but the limited driving ive done I like them, there not soft by any means but there much nicer then other skylines I've been in with coilovers, Depends what your after really
as I said there not soft.... but there not that hard either
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
