  • Replies 160
Posted Images
You'll get told at the briefing; but in case you didn't know, the state gov't > police force has seen fit to impose...
DOUBLE DEMERITS from to-day Sat-Sun-Mon-Tues-Wed inclusive.
That means, watch out on your trip home as well!!!
Oh how nice of them. As if that's not blatant revenue raising lol. Money spent on roads.......fail.
Also if you are heading to car park from the east, watch out for 2 BIG POTHOLES just before the underpass. You have been warned.
They have been there since before Christmas!
Dave
do you still have a premeet at cabra
Van
I was going to head straight to Clarendon since no one in the area was going to meet up, but we can meet up and head up there if you like. Maybe meet at Cab car wash around 8:45 and leave at 9?
Sure i'll see you there n my no is 0432452808 just in case
cheers
Van
Terry where did you find out about the double demerits?? I havent heard anything
I do apologise!
There was a media release yesterday that "double demerits" would apply from 00:01 this morning till 23.59 wednesday night as part of Operation Safe Return.
Now there's a "Media Release Archive" by NSW Police saying that there is a Correction, and that there will not be a "double demerits" after all.
This Correction was released by the Police at 11:10 this morning, which I didn't pick up till now.
Traffice Services Commander Max Mitchell still insists that Operation Safe Return will involve high HP presence with over 100,000 RBTs done over the 5 days till Australia Day.
We do regard the safety of all SAUers on this trip and on the way home with great empathy/concern and we trust that our responsible driving on the roads will justify this. :thanks:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
