hmmm sat phone lol. feeek ah well no use to me...
de mister thas what i thought by why 2?
also i have a 6 stacker FACTORY NISSAN mini disc player for anyone who wants it. it was in my centre console taking up space!!!
Rear demister and some cars have element at bottom of front windscreen in case wipers are frozen and stuck to screen.
No dude, WINDSCREEN de mister, not a second button for the rear de mister.
As Kiwi said above (now why didn't I make it that clear to start with :/ )
ohhhhh frikin cool...
also another pic. last one i swear...
i know that this one does, that lil button that says auto... it automatically folds my side view mirrors in when i lock my car, and opens up when i start it
is this a standard feature?
Thats actually to point your side mirrors at the rear tyres when you put it in reverse. The side mirrors folding in is an alarm feature, it utilises/integrates with the cars inbuilt ability to fold in the side mirrors. The button for that is on the left of the steering wheel.
Dunc, you rock haha just pushed it and chucked the car in reverse! thats awesome!!!!
yea have no idea what that box is. im just going to leave it there... any takers on the mini disc player? i mean i dont use it and i dont know who would, but im sure theres some OEM OPTION freaks out there?
that third switch on the left is to turn on the 'cold pack' which consists of a heater element under the front wipers, and also heated side mirrors. the mirrors should have been changed for compliance, so hopefully they neglected to do that for yours.
heated mirrors FTW :)
everyones right about the windscreen demister. if you look on the outside part of your windshield there are some orange lines. it was for japan incase the extremely cold winters made your wiper blades get stuck to the windscreen
edit: iaiaiaiaiain bet me.
Edited by AaronNM35
Minidisc you say. . . I have so many minidiscs from my DJ days. .
I could be interested.. any pics where exactly did it connect to. . or was it in the main unit.
Jules
zei201 - thanks for the info, everything was left on the car as is from japan, complaiance didnt get thier way with this one
Paramour - im currently capped on the net.. f**kin ghey haha. but it goes in to your centre console!!! will get pics up after the 5th
Hmm, is there a function on the remote where we can fold in the mirrors after you've left the car? I know with my grandis I can by double clicking the lock button on the remote...
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
