Hi all,
Would it be OK to fill up the R34 GTT with 91 RON petrol and then treat it with Nylon Pro octane booster?
From the reviews Ive read, Nylon Pro is the bets one out there and raises the octane rating past 98 PULP.
Its just I can get access to 91 petrol but not 98... atm.
If that's all you can get where you are atm, then it'd be best to do just that.
Whatever your mean average RON is, sitting in your tank atm, the octane booster is only going to shift it up marginally.
You'll get a better result with toluene (ie methylbenzene), depending on what amount you put in; but through regular skin contact and inhalation, it's carcinogenic.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5602755
if you got 98pulp in your tank and you drop in octane boost
how much more would it raise the pulp?
105pulp?
Doesn't quite work like that mate. As in theory adding more octane booster again would give you 111RON, then 118RON. Until you ended up with 300RON super fuel to run an engine with 37:1 compression...... laugh.gif
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5603658
Running Octane booster in general is a bad idea.
A once off is ok for emergencies... But then you can just stay off boost/light throttle and you'd be fine.
If you keep using it you'll run the chance of fouling plugs after a few tanks, and that'll make it just 10x worse over time than using proper fuel :)
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5604234
a mate of mine was a mechanic for repco a few years ago (the local repco store had a workshop on the side of it) and one day the nulon rep came through and had an octane test kit with him. my mate grabbed some BP ultimate out of his car and they ran a few tests. first they tested the fuel by itself. it was 98 octane (as you wuold expect). next they put in the standard measure of the pro strength octane booster (i think. this was about 5 years ago now so the memory is a bit dodgy). pretty sure this put it up to about 103 octane. then they put in double the normal dosage. the octane rating actually dropped back down to around 99 octane.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5604477
just run it on 91, unless you have an aftermarket ecu tuned for 98 it wont be a problem. with a stock ecu your better off with 91 than 98 anyway.
if you use octane boost make sure you have plenty of cash for spark plugs, you'll be changing them every 2nd tank. not to mention o2 sensors and other shit like that
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605357
are you missing that he said it was for a GTT, or are you taking the piss? the stock turbo ecu is tuned for minimum 95 octane fuel. running it on 91 octane will result in a loss of power, or if the knock sensors aren't working correctly a damaged motor. 95 or 98 octane will result it more power and safer knock levels.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605486
+1
Most people know that Australian 91RON unleaded is basically served as shots in Japanese bars... Our fuel sucks. Thus, imports not originally made for the Australian market should be run on 95 or better...
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605679
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
