your top speed must be awesome in that thing!!!! :P
Good figure bud....well done!.....I still would have thought you would crack the 300AWKW's though!....what PSI?
sorry i was wrong it was 285kw at the wheels lol
yeh it will crack much more, it was only tuned on ethanol because of the boost problem. -which is not so much of a problem anymore.
its pretty much tuned in 98, but on e85 for safety.
its at 20psi as the wastegate hole is a wee bit too small lol
feels f**king insane
look at the dyno results topic
Was the only difference between tunes your exhaust?
That's a neat install guys. I'm impressed. I didn't realise the unit was that small. No probs with fitting it in there at all by the looks.
A little bit of chopping on the cradles for the ETC reader to sit it in and mounted the solenoid in the battery box so very stealth.
Also had to make a small hole in the glove box cover to stop the dial hitting the lid. Turns out there is more room if you mount it a little higher.. lol
Solenoid in battery box. I must remember that - thanks, I like it!
Yes, the inside shape of that compartment varies considerably in profile.
What did you use to cut out the shape?
Edited by Commsman
I just measured the shape and cut by hand with a drill and scalpel. A bit of evening whittling. lol
Not to get too offtopic, but any idea why they hate them? Id be looking at going the Profec B II route
people feel that they're fiddly things, when adjusting gains and etc.
but everything that comes out of japan is fiddly. lol people should deal with it.
Yeah mostly I think it is people not reading the manual and/or taking the time to set them up properly. It's not quite as simple as "I WANT 20psi, K.. GO!"
Also, some think they can't handle huge boost and prefer to go for the Blitz dual solenoid units. The theory there is that the dual solenoids can handle fast ramping, huge boost setups better.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
