Fitted 575cc injectors to the Stagea today, along with a new Z32 AFM to complement the Garrett 3076. Tomorrow after work, I'll limp her to the tuners for a new tune on the Nistune ECU. Should pick up a whole heap of power.
Then on Saturday its off to the tyre shop for a set of new rubber and a wheel alignment.
Just in time for the track day on Monday!!!
:thumbsup:
Had a busy day on the Stagea today... Had 4 new Falken 912 tyres fitted today and a 4 wheel alignment. Think these will be better than my cheap RV tyres.. lol
Also made a little mod to the blow off valve to block off the small hole to improve boost response.
Can you elaborate Andy? Sounds easy to do, does it make a difference?
In the BOV there is a small hole that allows the air to bleed unregulated. That is the hole I filled.
After 1 day results are, certainly comes on a little stronger and build boost a little faster but at a price. Throttle is a little more stuttery but not a problem BUT I have the Turbo making a loud noise. Not sure what you call it but it but like a high pitched and quite audible around.
I am going to try a little mod today on it today and will let you know how it goes.
yeh it used to do that before a tune but not as much... its surging..kinda sounds like the BOV gate isnt opening at all though which is strange.
once the tune came its went to a sharp phiewsshhhhh sound.. ill try record it on the way home n upload.
maybe a temp fix is a 2mm hole like scott said.?
That is the plan today..
Could well be that my BOV needs a bit of TLC...
andy did you put the vacuum hose back on the other side??
i've dont this before.. the gate opens at about 6-8psi and you hear a shhhhhhhhhh on accel.
it actually doesnt flutter, seeing as its already opening.
tune issue for surge? nup
i rekon its throttle speed related. maybe the factory/impul doesnt close the throttle as quickly, or maybe much faster. i get a tiny bit of flutter, but i also think its due to BOV placement in the inlet tract. if it was before the FMIC the pressure wave maybe wouldnt be created?
well, its mechanical, no amount of tuning can change that :P
however, being a valve that uses the pressure difference of the throttle body to open/close, thats why i put it down to ECUs.
at lower RPM you have throttle limits, andys may limit it differently. his may slam the throttle shut when he backs off, or maybe its more gentle.
andy put your stock ECU back in and go for a drive. see if it does the same thing
completely forgot he had an aftermarket.
or tell craig to get off his lazy ass and do it! lol
but Iain, mine and Scotts used to both do this before the tune..mine not as much as the clip, but none the less, it did.
once we tuned it stopped?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
